Coromal van owners
Submitted: Wednesday, Apr 12, 2017 at 11:00
chris a
G Day I have a little Coromal Pop Top Excel 452
I need a jack for it . It has independent
suspension
A little help would help thanks you
Reply By: Malcom M - Wednesday, Apr 12, 2017 at 11:05
Doesn't it have any chassis rails you can jack from?
610157
Follow Up By: chris a - Wednesday, Apr 12, 2017 at 16:13
Yes Malcom it has provision for some kind off side jack in the ends of one of the cross member
880094
Reply By: Member - Blue M - Thursday, Apr 13, 2017 at 02:25
Chris, you may be looking for something like this,
Trail-a-mate
They are a little bit expensive but not a bad side jack, can also double as a jockey wheel.
610174
Follow Up By: chris a - Saturday, Apr 15, 2017 at 09:59
Thanks Blue
I was look for some thing less expensive It only 1090 kg
May be some kind of screw side jack Thank mate
880146
Follow Up By: Shaker - Saturday, Apr 15, 2017 at 13:35
Maybe ask Coromal what they recommend.
880149
Reply By: 9900Eagle - Saturday, Apr 15, 2017 at 14:07
I used to jack
mine up under the spring if I was say doing bearings and then support the chassis by pigstying or use a manufactured stand.
Or jack up the chassis behind the axle if changing a tyre and use a piece of timber or plate to spread the load on the chassis
610235
