Wednesday, Apr 05, 2017 at 08:04
You don't need anything other than the compression bandages for snake bite (which is also the treatment for most of our venomous spiders too), pressure / immobilisation, splint limb (if applicable), and get help asap.
Anitvenom has a short shelf life, and isn't always needed, definitely needs to be administered in a hospital if possible, but can be administered by a vet if situation is dire.
If you do everything right, they simply cut away the bandages in hospital where the bit occurred (the X on the bandage) do a swab and
test.
Then a poly or mono antivenom will be at hand if needed.
Many bites are 'dry' but you just never know.
I am sure the advanced
first aid courses should cover the correct pressure immobilisation, they might not cover all the little tips / tricks / knowledge of an advanced course, or the training like a snake catcher gets with their internal programmes.
879816
