Projector DC/Solar 25 amp battery charger
Submitted: Monday, Apr 03, 2017 at 15:01
Jerry N
Hi out there
My question is that I have dual battery system with a Projector 25 amp DC/Solar battery charger in my D Max with a connection through Anderson plug to my camper trailer which has a battery for lights and a inverter(from auxiliary battery)
I purchased a caravan and bugger me dead it has the same charging system .
My question is ,can I attach these in line with each other .
The problems I can see is if I connect to my present Anderson plug (as mention above) the caravan will charge all the time , so that is out
Any ideas would be appreciated
Regards Nico
Reply By: Member - Bigred13 - Monday, Apr 03, 2017 at 19:47
What I would do is run a heavy cable from your starting battery through the Anderson plug to your caravan and use your Auxiliary battery and charger to run anything in your DMax .
609899
Reply By: Member - Phil G (SA) - Monday, Apr 03, 2017 at 23:03
I agree with BigRed13.
609909
Follow Up By: Member - Bigfish - Tuesday, Apr 04, 2017 at 08:57
Agree with both...that would be the best way to configure.
879792
Reply By: Jerry N - Wednesday, Apr 05, 2017 at 13:14
Yes after a lot of thought it is the only way to go
Probably look at only use caravan solar system
Thank you for your feed back
Regards Nico
609938
