Navara alternator
Submitted: Saturday, Mar 18, 2017 at 09:27
ThreadID: 134480 Views:3847 Replies:3 FollowUps:0
Can any one tell me if the 20011 D40 navaras have a fixed voltage or a variable voltage altnator.
Reply By: HKB Electronics - Saturday, Mar 18, 2017 at 09:56
The 2011 D40 I believe has an ECU controlled alternator, you'll most likely find the charge voltage drops to a very low level after a few minutes.
I also believe the smart charge function can be disabled by disconnecting a wire and the charging will then revert to fixed voltage charging.
Do a search of the net for green wire and blue wire mod for the D40.
Leigh
AnswerID: 609480
Reply By: Member - Dennis B - Saturday, Mar 18, 2017 at 16:39
thanks Leigh
AnswerID: 609492
Reply By: Member - Andy M (QLD) - Saturday, Mar 18, 2017 at 22:17
I didn't worry about green wire mod. I just unplugged the plug at the negative battery terminal on what I think is called a shunt and it reverts to a normal alternator. Puts out at least 14 volts all the time. Been running it like that for over a year with no problems. Can plug it back in for servicing or whenever. I did tape up the loose plug though to keep it clean.
AnswerID: 609502
