Solar Powered LED light string - not working
Submitted: Monday, Mar 13, 2017 at 15:33
ThreadID: 134456 Views:3994 Replies:3 FollowUps:5
I have a cheap solar powered light string that now doesn't work. I should just buy another, instead of trying to fix it, but that defeats the purpose of being retired.
I have previously cut the lead from the solar panel to the lights and inserted a waterproof joint plug (50% of the value of the lights). Soldered joints and shrink wrapped. Allows the lights to remain in place and the charging panel put in the full sun. Worked well for the last 3 months.
Replaced the battery and left on charge for a full day in the sun. No result.
Checked the continuity of the leads from the solar module to to end of the light string. All good. Checked battery voltage, 1.28 and had the same voltage at the end of the light string but no lights. Checked on/off switch all good.
So what am I missing? If I have 1.28V at the end of the string why are the LED's not coming on. Does the small module in the solar panel unit do more than just act as a battery charger?
I know I should just spend another $10 and forget about this problem. But.....
