Caravan wiring
Hi everyone, I'm after some advice or help with changing the connections to my toe vehicle. The van is a Windsor rapid, there is no battery installed in the van, and had a 12pin plug on the van. There is not really much room to install a battery and the patrol has a second battery and Anderson plug already installed. So there is a large gauge orange cable that goes to a fuse panel for the fridge, at the same fuse panel are two reds that do the internal and external lights. The orange is at the trailer plug but the reds aren't, so who knows where they pick up their power. I would like to change the wiring so all the running lights and brakes are through a 7pin plug and the lights and fridge are powered by the Anderson plug and second battery. Any advice is much welcomed.
