Steinbauer performance system move from 76 to 200 series?
Submitted: Monday, Jan 16, 2017 at 14:23
Member - McLaren3030
Hi Guys, I currently have a 2010 76 Series GXL single turbo V8 fitted with a Steinbauer performance system. I am upgrading to a new 200 Series GX early this year, and was wondering if I can swap the Steinbauer from the 76 series into the 200 series. Is the system compatible?
Reply By: Shaker - Monday, Jan 16, 2017 at 14:34
Part numbers & price is different, although I'm sure you would have Googled that.
Other than that, I can't help.
607635
Reply By: Cruisevessel - Monday, Jan 16, 2017 at 14:43
No as 76 is single turbo and 200 is twin turbo. A different fuel system with different injectors.
Sell it and buy the correct unit is the safest and correct thing to do
607637
Follow Up By: Whirlwinder - Monday, Jan 16, 2017 at 15:06
I think you should sell it and NOT put a chip of any sort on the 200. The consequences are $22000 for a new short motor.
I have seen the results of a chip on a 200 and it was not pretty. They have a lot of power and heaps of torque already. A 3" exhaust will be about all it needs.
The good thing is "it's your call and it could be your bill".
Ian
877313
Reply By: Notso - Monday, Jan 16, 2017 at 15:54
You want to CHIP a 200?
607638
Follow Up By: Member - McLaren3030 - Tuesday, Jan 17, 2017 at 15:49
Not necessarily Noto, just thought I'd ask the question, particularly as my 76 series will likely go to auction after I trade it.
877364
Reply By: Paul E6 - Monday, Jan 16, 2017 at 18:26
i asked Steinbauer about moving a module between 2 models of the same make. They said no.
607641
Reply By: Member - Boobook - Tuesday, Jan 17, 2017 at 08:24
IMHO you really need to ask these type of questions of the manufacturer or vehicle specific forums like LCOOL.
607655
Follow Up By: Member - McLaren3030 - Tuesday, Jan 17, 2017 at 15:46
Thanks Boobook, I have an enquiry on Lcool as
well
877363
Reply By: Member - McLaren3030 - Tuesday, Jan 17, 2017 at 15:51
Thanks for all the replies, I spoke with Steinbauer & they advised that they are different models because of the twin turbo.
607669
Reply By: Paul and Mel - Wednesday, Jan 18, 2017 at 19:45
How have you found the 76? I'm looking at buying one.
607720
Follow Up By: Member - McLaren3030 - Sunday, Jan 22, 2017 at 19:24
Did everything I wanted it to do. As
well as the Steinbauer, I also fitted a long range fuel tank, bullbar & winch, heavy duty clutch, roof rack, drawer system, Sat Nav & reversing camera.
877644
