Codan 3042 Antenna tuner
Submitted: Tuesday, Jan 10, 2017 at 07:32
Member - Boobook
A bit techie and specific I know, but I'll throw it out there in case someone has done this.
Has anyone sucessfully used a Codan 3042 tuner and whip on their 4wd? I have a Codan 9323 ( 9360 actually) with a 9350 antenna. Previously I had the antenna on my rear wheel carrier but want to get away from that this time on my new 200 because it is a lot of weight and leverage up high on the wheel carrier on long corrugated tracks. I know I could use a 3040 tuner / whip but that would have to be up high too. I don't want to mount it on the front bullbar either.
The 3042 can be mounted separately to the whip, so I can mount the tuner down low and the whip up higher, but there can be issues with clearance around the wire from the tuner to the whip.
Sorry for the numbers and Jargon but if anyone has done this it won't be gobbley goop to them.
Also, has anyone solved the issue a different way?
Reply By: Baz - The Landy - Tuesday, Jan 10, 2017 at 08:09
Hi Boobook
I have the 3040 mounted on the rear of the vehicle canopy and it works
well. It is fixed half-way up the canopy and I don’t detect any degradation in performance.
On the “Old Landy” I had the 3040 mounted on the bulbar down low and attached the whip which had a diameter smaller than a UHF antenna, again, this worked quite
well, and no issues from a mounting perspective in terms of legailities. The picture doesn’t show it too
well, but it is mounted where a winch would normally go.
Whilst the 9350 has some weight to it and would create some leverage mounted at the rear, its footprint is small, and whilst weight does add up cumulatively when adding items, will it be so great to create a problem?
If the TVAN accompanies you on most trips is mounting the antenna on the TVAN an option and connect to the vehicle for input to the radio unit (just thinking?)
The Landy 3040 mounted on bullbar
The (new) Landy 3040 rear mounted
Good luck with it…Baz
607417
Follow Up By: Member - Boobook - Tuesday, Jan 10, 2017 at 08:20
I saw your 3040 mount, nice. I have a mount on the spare carrier, and with the spare as
well as the 9350 it just seems like a lot of weight and leverage. Previously I had the 9350 on a specially made bracket on the jerry holders, it seemed more solid but blocked a tail / stop light ( even though the rear bar has another one).
With a new vehicle, and me not going away for a while i want to look at all options, then install the accessories, rather than the ad hoc way I did it last time. I have a focus on weight reduction, especially up high if possible
I did think of the TVan but want the vehicle to be self contained.
877121
Follow Up By: Baz - The Landy - Tuesday, Jan 10, 2017 at 08:24
Hi Boobook
The 3040 on the rear has survived everything thrown at it, and is
rock solid.
And I am with you on having the vehicle self-contained, understand that fully.
Cheers, Baz
877123
Reply By: The Bantam - Tuesday, Jan 10, 2017 at 23:37
Ya not greatly blessed with a lot of choices
Looking at the detail might help.
Mounting the HF on the spare wheel carrier above the wheel mount will definitely add some leverage and stress.
You could reduce that leverage and stress mounting closer to the hinges.
A lot of the Amateur radio guys that persist with HF mobile mount on the towbar, with a tongue for the purpose .... change tongues when they want to tow something ... this does not help you.
but maybe a bracket off the towbar or chassis.
Ya probably dont want to do what the army do ....... bolt it thru the roof or the side of the panel work ........ BUT ..... taking out one of the rear windows and replace it with a panel and mount on that might be an option ...... the window could be refitted upon resale.
607450
