Trek Comment: Owen Springs Reserve
The start point on the Details page appears to be incorrect. I think it should read Larapinta Drive, not Stuart Highway.
Kevin
2019 Mitsubishi Cross
Reply By: KiwiAngler - Friday, Aug 26, 2016 at 21:06
Kevin
I have noticed this in quite a few of the treks - plus starting point is same as finishing point
AnswerID: 603878
Reply By: Member - Stephen L (Clare SA) - Friday, Aug 26, 2016 at 23:00
Hi Kev
Depending on which way you are starting. You can do it from either direction, and if following the track notes and want to do it in reverse, just start at the bottom and work up.
It is an easy drive and does nor matter which way want to start it from.
Smile like a Crocodile
AnswerID: 603882
Reply By: Kevin S - Life Member (QLD) - Saturday, Aug 27, 2016 at 07:32
To be more specific I am referring to the trek as it appears in EO Traveller. The trek runs between Stuart Highway in the south and Larapinta Drive in the north. But the address for the start and finish are identical. Can't be correct. That's all. No matter which way I drive it that will still be wrong. Don't know about how it appears in the Web site. That is not the issue.
Kevin
Kevin
AnswerID: 603888
Follow Up By: Member - Stephen L (Clare SA) - Saturday, Aug 27, 2016 at 08:00
Hi Kevin
Sorry about that, I was not aware that you were refering to EO Traveller. There seems to be quite a few bugs in there ar the moment, have you let David know, so he can get it sorted?
FollowupID: 873508
Follow Up By: Kevin S - Life Member (QLD) - Saturday, Aug 27, 2016 at 09:03
Thanks Stephen. I will do that later in the day if he has not picked it up from this thread.
Is it as cold down your way as it is here in Alice Springs? 2 yesterday and 3 this morning. Brrr!
Kevin
Kevin
FollowupID: 873510
Follow Up By: Member - Stephen L (Clare SA) - Saturday, Aug 27, 2016 at 09:10
Hi Kevin
Very similar mornings down here in Clare at the moment.....but having said that when you live here all the time, that is not as cold as continual morning of well below zero....lol
The days have been real nice, in the high teens and one day a couple of weeks ago it was 22...just perfect.
It now looks like a change of season, all the blossom is now starting to add colour, the country is looking in top condition around here and that continuous rainy days have now stopped.
Keep Warm
FollowupID: 873511
Reply By: Member - Ross N (NSW) - Saturday, Aug 27, 2016 at 10:06
The directions were probably written by the same Irishman who said when asked directions to Dublin replied after some thought, " If I were going to Dublin I wouldn't be starting from here".
Oops, sorry not Friday.
Ross Nielsen
AnswerID: 603890
