Monday, Jul 18, 2016 at 21:53
Batt's
You can fit air bags, heavier springs or even blocks of wood between the chassis and the axle to lift a sagging rear end and it won't make any difference. The chassis is still at risk if there is too much heavy material too far back behind the axle.
Look at this extreme example. Hook the bucket of a large back hoe over the tow ball and push it down to the ground. The chassis would break but assume it doesn't.
The springs would compress, the whole car would pivot on the rear axle bearings and the front wheels would lift off the ground. Now install heavier springs and do it again.
The springs will still compress, the car will still pivot on the axle bearings and the front wheels will still lift off the ground.
Heavier springs or air bags can not support the far end of the chassis. It is sticking out the back like a plank on the side of a pirate ship. It has been designed to take a certain amount of flexing that will be caused by the correct loads but give it too much and it will eventually break.
I think from memory this model Triton has a maximum carrying capacity of 930 kg. If you fill it with about 480 kg of people in the five seats, about 70 kg of fuel in the tank and the remaining 380 kg in the back with the heaviest items as far forward as possible, it will be fully loaded but the rear end will not be sagging.
The rear springs will be flat though. They are supposed to be so the roll understeer stability assisting feature of the rear
suspension will work in corners.
That is how a dual cab is supposed to be loaded. You can't ignore the fact that those five seats are major load bearing areas. If you can't fill them to the maximum then you can't put the rest of its carrying capacity out the back. You have to accept the fact that you can't fully load the car without taking it outside its design limits.
If that weight distribution does not suit some owners then too bad. I am not aware of any cars that have adjustable locations for suspensions, engines, bodies or whatever so they can be altered to suit whatever the owner wants to do with them.
This particular car may have bent its chassis with just the things hanging off the back. Once again going from memory I think the maximum tow ball weight is 270 kg. Many manufacturers,
mine included, say a WDH must be used for any weight above half the maximum. If Mitsubishi says that then those four jerries, the wheel and the carrier would weigh more than half the ball weight. Their location
places them directly over the tow ball so the weight might as
well be on it.
Of course when you are not towing anything you can't use a WDH so those things alone assisted by whatever is inside
the tub right at the back could have caused the damage if the roads it has been driven on were rough enough.
872149
