Camper trailer gas connection to weber Baby Q
Submitted: Monday, Jul 04, 2016 at 13:18
GHThommo
Hi all,
We have just traded in our Cub on a Goldstream Wing 2. We have had an external gas outlet put on the side so we can connect up our Weber Baby Q. The outlet has a bayonet fitting. We have a gas hose to connect to the van outlet. Do we need to connect this hose up to the Weber via its regulator or since the van gas bottle already has a regulator on it can we remove the Weber regulator line and connect from the van outlet directly into the weber.
Hope that makes sense,
Thommo
Reply By: Gundarooster - Monday, Jul 04, 2016 at 14:30
Thommo,
We run our baby Q straight off the baynet fitting on the van and the original hose and regulator with a gas bottle for when we take the off road camper trailer.
Both work equally
Gundarooster
602072
Follow Up By: GHThommo - Monday, Jul 04, 2016 at 19:14
Thanks Gundarooster.
Thommo
871697
Reply By: Member - Bigred13 - Monday, Jul 04, 2016 at 14:41
Hi Thommo,yes there is a hose you can buy that has bayonet fitting on one end and a fitting to go into Weber ,most
camping shops have them in varying lengths ,always better to get long length as the wind does change ????????
602074
Follow Up By: GHThommo - Monday, Jul 04, 2016 at 16:31
Thanks Bigred13. I do have a hose with the bayonet fitting. My query is whether I have to run that through the weber regulator or whether I can remove the weber hose and regulator and run the bayonet hose direct into the weber (since there is already a regulator on the van gas bottle). I don't want to take an extra gas bottle with me.
Thoomo
871693
Reply By: Member - Bigred13 - Monday, Jul 04, 2016 at 16:57
Thommo ,yes sorry , what I meant to say was, yes connect your hose directly to the weber , no need for regulator as it already has gone through regulator ,it is just another outlet ,same as HWS ,stove etc ,cheers and let me know when the T bones are ready ????????????
602082
Follow Up By: GHThommo - Monday, Jul 04, 2016 at 17:06
Thanks Bigred13.
871695
Reply By: swampy - Monday, Jul 04, 2016 at 19:14
hi
Only regulate your appliance bbq, hot
water once .
2nd option
Install a t piece with ball valve and female POL [with dust cap ]
Where between van bottle and van regulator .
This system allows for any bbq hose and reg found in any town .
If the bbq hose is not long an extension of up to 3mtrs can be purchased at any gas store.
swamp
602088
Reply By: GHThommo - Monday, Jul 04, 2016 at 19:18
Thanks Swampy.
602090
