coolant leak gu patrol 3ltr
Submitted: Wednesday, Apr 20, 2016 at 18:44
ThreadID: 132184 Views:3807 Replies:1 FollowUps:0
hello all, just some information. had a small coolant leak from engine of patrol.
was told, it could be from anywhere. head to block, block to timing case, timing case to water pump housing. I tried a new product from Nulon called, radiator & engine block stop leaks. it comes in a round bottle of 500ml ,not in the bottle like injector cleaner
which they also sell. it contains kevlon fibres and forms a glass type permanent seal
IT WORKED.. it stopped the leak and nulon technical department told me I could leave it in the coolant, will not block radiator. seems a good alterative to costly repair.... bill
Reply By: adam d1 - Saturday, Apr 23, 2016 at 10:58
hi bill
just saw your thread on coolant leak. i have the same problem 2010 gu. seems to be coming from timing cover but hard to tell. over night it runs down the block onto ac compressor and diff housing. as this car has been nothing but trouble im not keen on propper fix so im going to try what u did. hope i have same results. cheers adam
AnswerID: 599055
