Electric brakes on avan cruiseliner
Submitted: Thursday, Apr 07, 2016 at 12:14
Member - bill j (VIC)
Hi all can't get power to magnets, power both sides of plug ok using 12 pin, also has any body rewired brakes, notice wire comes out of floor to brakes.??
want to run a wire to each wheel. Van is Aliner cruiseliner.
Thanks billj
Reply By: TomH - Thursday, Apr 07, 2016 at 17:10
You dont need 8 B& S cable for brakes as it will never go into the connector,I used twin 6mm automotive cable and wound them together and had no trouble stopping a 3T van
On connectors from car to van PIN 5 is ALWAYS the electric brakes regardless of whether its a 7pin flat or round or a 12 pin flat. Earth is always PIN 3
As said make sure earth is good right back to car If tail lights are going it probably is.
Look in your connector on the van and tell us what colour wire is on each pin
Not enough clear info really.
Where is wire coming out of floor above axles ? at front of van???
There is only one wire for brakes in the connector and it uses the common earth on pin3 which is earth for everything unless you have something likea fridge wired through an Anderson Plug THEN you use 8 B&S or heavier for that only
598315
Follow Up By: Member - bill j (VIC) - Saturday, Apr 09, 2016 at 14:59
Hi tom the cable to the RH brake comes out of the floor 3/4 way above axle is about 2.5 metres long the LH cable comes out on edge of van floor above brake.
about 35cm long.
The brake controller is wired to pin 12 red. earth pin 10 black
plugged into car power to van plug ok.
check with circuit tester at brakes no power.
will get twin 6mm and rewire.
thanks
867565
Follow Up By: TomH - Saturday, Apr 09, 2016 at 17:03
Most unusual and equaly unwise. What brand is the brake controller.
It is always best to adhere to standard wiring connections as should you hook up to another vehicle clouds of smoke could be the result.
Electric brakes only have one wire from the vehicle It is often blue and as I said is ALWAYS ON PIN 5 regardless of the type of connector.
The earth normally is the standard earth wire on pin 3.
You obviously have a 12 pin flat plug and pins 8 to 12 are heavier for the likes of fridges and battery charging but NEVER BRAKES. Also your power circuit in the tug for the brake controller should have an auto resetting circuit breaker in it NOT A FUSE as I saw with a unit sold by Caravans plus.
Fuse blows no brakes Circuit breaker will reset at least.
I notice on an AVan
forum they seem to use Scotchlock connectors If your van has them get rid of them The inventor of them should be hung
Read this and make sure you have a proportional one like a P3 or a Prodigy or a Redarc Tow Pro
controllers![Brake wiring](https://cdn.exploroz.com/images/forum/uploads/155527_20__TN600F.jpg?gid=137253)
Brake wiring
![Van brake wiring](https://cdn.exploroz.com/images/forum/uploads/155527_21__TN600F.png?gid=137254)
Van brake wiring
![where to hook brake wire](https://cdn.exploroz.com/images/forum/uploads/155527_22__TN600F.jpg?gid=137255)
867569
Follow Up By: Member - bill j (VIC) - Saturday, Apr 09, 2016 at 17:58
Hi Tom it's a Hayman Reese controler and there is a 20 amp breaker, have had this in the car for 3 vans this is the first have have problems not with the car. the van will probably get a auto sparky to sort it out.
867571
Follow Up By: TomH - Saturday, Apr 09, 2016 at 18:47
Which model because some of them are the old type You want a proportional type that applies the brakes according to how fast you are decellerating.
The old type like the Redarc and the Hayman Reece (mostly rebranded Tekonsha) ones you dial up how much you want and thats what you get ALWAYS So if you have it set for a nice dry road and it rains and you dont back it off it will lock the brakes. The proportional ones are much better and safer despite what the "Ive had it for 40 years" brigade say. LOL
It may be that the car has the brake wire on pin 5 (Normal) and the van has it on another one. From what I read on the Avan
forum their wiring leaves a lot to be desired. In this link
Brake controllers the outside top two are good ones and the middle one underneath
They are rebranded Tekonsha P3 Prodigy and the bottom one is a Redarc tow Pro The middle top one is an old technology set and crash model
867574
Follow Up By: Member - bill j (VIC) - Saturday, Apr 09, 2016 at 19:00
Yes it is a Proportional Brake Controller.
867576
