extractors and exhaust
Submitted: Friday, Jan 29, 2016 at 15:58
ThreadID: 131488 Views:6579 Replies:10 FollowUps:4
Gday members , after some advise , just purchased a 2002 100 series Landcruiser with the 4.2 diesel 1hz motor, wanting to put extractors and a 2 1/2 inch exhaust on it , . Has anyone any recommendations of what shop to use around Perth , approximate cost I should be looking at and type of headers to use
Cheers Todd
Reply By: Member - johntoyo - Friday, Jan 29, 2016 at 16:04
Todd I would recommend for just about any thing Landcruiser you try the Lcool.org web site. I would imagine your answers are already on that site.
Some one on this site may have your answer but the Lcool site is brilliant for that sort of questions.
John.
AnswerID: 595601
Reply By: Todd S4 - Friday, Jan 29, 2016 at 16:07
cheers John
AnswerID: 595602
Reply By: Member - Alastair D (NSW) - Friday, Jan 29, 2016 at 17:16
Todd,
I agree that LCOOL is the place to go.
If you have a non-turbo engine then I doubt that you will find enlarging the exhaust will make much difference. You are saying 'putting extractors on'. This is more what is done on a petrol motor. On a diesel the normal approach is to enlarge the dump pipe and exhaust but this will only show real benefit where there is significant back pressure as occurs with a turbo engine.
AnswerID: 595607
Reply By: Tony H15 - Friday, Jan 29, 2016 at 17:47
I've never put extractors on a L/C but have on two Hilux diesels, not sure if the results were worth the trouble though. Never noticed any power increase at all; however, the fuel consumption improved by about 1-2 LP100. Considering the price of extractors I wouldn't bother! Almost any exhaust shop can supply and/or fit, I got mine from Carline in Rockingham.
AnswerID: 595609
Follow Up By: Jackolux - Friday, Jan 29, 2016 at 20:12
I fitted extractors and exhaust to a 2.8D Hilux all l got was more noise .
FollowupID: 864308
Reply By: Bob Y. - Qld - Friday, Jan 29, 2016 at 18:32
I'd suggest you save the dollars, and put them toward a turbo kit. Will get more bang for your buck.
Have seen a few 1HZ's with extractors/exhaust...sounded alright, went okay, but still pretty breathless.
I put extractors & 2" exhaust on an '82 Hilux diesel. Might have improved it marginally, but sounded good. :-). Bit of a case if you add 10% to almost nothing, you've still only got 10%.
AnswerID: 595613
Reply By: TomH - Friday, Jan 29, 2016 at 20:20
A lot have turboed them but then if not careful blow the bottom end. Lcool will tell you the good and bad about 1HZ.
The 1HD FT or 1HDFTE motors were far and away better. Dont know if what you want to do will make it any faster.
A friend bought one and constantly regretted it as it crawled up hills with a van on and wasnt very fast on the flat when towing either.
As said a bigger dump pipe is the usual I did that and a 3 in exhaust on a 1HDFTE and it went better but then it went pretty good before I did it
AnswerID: 595618
Follow Up By: Todd S4 - Saturday, Jan 30, 2016 at 09:58
Thanks Tom
FollowupID: 864330
Reply By: Member - ross s - Saturday, Jan 30, 2016 at 06:38
Hi Todd S4, I just put a Pacemaker 2 1/2 inch system with extractors on my 1hz troopy. It was a fairly straight forward diy installation. Just had to cut the old exhaust off as the flange nuts were seized and also replace engine studs as the nuts had also seized. I didn't want to go down the turbo road but just wanted a little more engine response. The car now accelerates alot smoother, is better on take off, on hills. ( for a 1hz anyway.) It also feels alot more relaxed at 100 kph. Downside is less engine braking and very slight increase in fuel due to it accelerating better off the line. It has made the troopy, for me, more comfortable to drive. Cheers.
AnswerID: 595638
Follow Up By: Todd S4 - Saturday, Jan 30, 2016 at 09:57
cheers Ross
FollowupID: 864329
Follow Up By: Member - ross s - Monday, Feb 01, 2016 at 21:04
Forgot to say the complete system, extractors to tailpipe, was $1400. The shop wanted $400 to fit it. They seemed to think that it is difficult to fit a pre made to fit system. After four new hangers and engine studs and nuts plus four hours of my own labour( had to remove a broken stud left from the previous owner. ) all was up and running for under $1500. Alota loot but my exhaust needed replacement anyway.
FollowupID: 864501
Reply By: Mikee5 - Saturday, Jan 30, 2016 at 12:59
Hi Todd,
I put a Beaudesert Exhaust kit onto my 2003 1HZ powered 100 series, it included Pacemaker extractors and stainless system. While it doesn't make it a rocket ship the increase in power was noticeable while driving so maybe 5 kw as a guess. I am reluctant to turbo an engine that was never designed for it. I tow a 2 tonne caravan and with patience we get there. Price was $600 second hand - thanks to Gumtree.
AnswerID: 595659
Reply By: wholehog - Sunday, Jan 31, 2016 at 21:59
You actually have a HZJ105 series Landcruiser.
The 100 series is for the Independant Front Suspension model.
Save your extractor, fat exhaust and turbo money and do it properly.
Fit a 24 valve 1HDFTE engine and suitable gearbox like Toyota should have done to the 105 series.
AnswerID: 595741
Reply By: Batt's - Monday, Feb 01, 2016 at 14:16
I have owned 3 turbo 4WD's but have also had extractors and larger exhaust put on 2 non turbo diesels. They were older 4WD's a 2.4 ltr 4 Runner, a 60 ser cruiser it made both vehicles more driver friendly than they were. I would recommend getting a quality system where they match the exhaust to the extractors/headers while they may not be cheap it will be worth it and you may get approx 10 to 15% improvement in power it varies from one vehicle to another. Realistically economy should improve slightly after time because when you get them you'll be a bit heavy on the gas pedal having fun playing around with the extra power you now have then you will eventually settle down back to how you use to drive everyone does it . You will notice even more improvement if you compliment the exhaust by doing the intake side by fitting a snorkel and furthermore again by fitting an air filter like a K&N if you like.
http://www.genie-exhaust.com.au/
AnswerID: 595768
