Saturday, Jan 02, 2016 at 18:38
When you speak to "caravan people", many of them can't believe that other trailer formats do not have sway problems.
Years ago I had a bloke, talk to me like I was an idiot because I did not have some sort of weight distributing hitch on a 1 tonne box trailer ,and he ranted that I needed to have at least 100Kg ball weight.
It must be understood that part of the problem is that the single axle trailer is a fundamentally unstable format .... and the taller, longer and higher the unit gets, the worse the stability problems get.
It gets even worse when weight is concentrated at the ends of the caravan ... as it is in some designes.
It also follows that the shorter and more centrally loaded the trailer is the less unstable it will be.
So someone towing a short, low brick of a trailer will probably experience none of the problems that terrify many caravan owners.
I have no problem keeping the ball weight low .... but on your trailer .hell 10% or 20Kg is not going to be a problem.
What I would strongly recommend is keeping as much of your weight as low and centrally located as possible ....... this with promote stability and as that weight ( like
water tanks) changes, the behaviour of the trailer will change less.
One other reason for stability problems with caravans towed by passenger cars is ..... the passenger car squirms under the load of the caravan, because it is a passenger car and the
suspension is designed to be soft and baggy and there is mostly a long distance between the hitch and the centre of the rear axle ..... squirming and a long lever..... this squirming excites the instability in the trailer.
Ya probaly wont have that problem either.
One thing I strongly recommend is shock absorbers on the trailer.
I remain gob smacked that many big expensive caravans have no shock adsorbers. so they have nothing stopping the trailer once excited from hopping from one wheel to the other,
The one thing that would realy concern me is such a light van is windage ..... you may have problems in crosswinds and with passing trucks ..... all the more reason to keep ya weight low.
OH and remember ..... in heavy transport, weight distributing hitches and anti-sway devices do not exist. ...... these devices are a patch up to correct a specific problem of a fundamentaly unstable combination.
594409
