nissan gu patrol noisy fan belt
Submitted: Monday, May 24, 2004 at 16:10
ThreadID: 13119 Views:2164 Replies:4 FollowUps:1
hi everyone,
does anyone have a solution to noisy sqeaky fan belts,on 4.2 td. Have tried 'belt grip' etc, but limited effect. Thought it might be the belt tensioner, does it have a sealed bearing, or can it be lubricated. Truck has done 95000k original belts
REGARDS
Reply By: crfan - Monday, May 24, 2004 at 16:54
Try silicone 808 spray if that doesnt help you can try soap etc but probaly have to replace the belts (put on you spares and keep the old ones for spares if they are in good nick)
AnswerID: 59923
Reply By: locallaw - Monday, May 24, 2004 at 18:08
Gidday,Sell the GU and buy a TOYOTA.Problem solved.
Seeya Locallaw
AnswerID: 59937
Reply By: hoyks - Monday, May 24, 2004 at 21:33
New belts. and give the pullies a clean while they are off.
AnswerID: 59985
Follow Up By: Michael - Tuesday, May 25, 2004 at 08:57
Yep! new belts and keep the old ones for spares, Nissan ones are not cheap!!
FollowupID: 321622
Reply By: Rob W. - Tuesday, May 25, 2004 at 08:10
Bill,
Not sure about the 4.2 motor, but on the 3.0td there is only 1 belt, anyway mine was sqeaking, tride the lube on it, no change, bought a new belt and fitted it...no change, had the tensioner replaced (under warranty) ...no more sqweak.
Rob
AnswerID: 60020
