jacks
Submitted: Wednesday, Dec 16, 2015 at 16:32
Member - Barry P (VIC)
pros and cons of the kci 2000 kg scissor jack?,thinking of buying one,thanks for future answers bye barry
Reply By: Frank P (NSW) - Wednesday, Dec 16, 2015 at 17:36
I was given the Aldi version a couple of years ago. I use it for maintenance at
home, don't carry it on the road. It does what it's supposed to do with ease. I've had no problems with it at all.
593873
Follow Up By: garrycol - Wednesday, Dec 16, 2015 at 18:42
I also had the Aldi version and it failed under a very light weight vehicle. If you get one, treat with caution.
Forum%20Posts%20Album/Jack_zpse5e97033.jpg.html" href="http://s42.photobucket.com/user/gazzz21/media/
Forum%20Posts%20Album/Jack_zpse5e97033.jpg.html" target="_blank">
862213
Reply By: Capt. Wrongway - Wednesday, Dec 16, 2015 at 19:50
I purchased one of these about 18 months ago. Took it on every trip but only used it occasionally. Used it once or twice on my Prado, fully loaded, with no problems. About 3 months ago my son took it with him on a big trip half way around the country. He used it many times for flat tyres on this Patrol and camper trailer. On the last occasion, while changing a flat front tyre on his Nissan GQ, the jack virtually exploded. The motor/gearbox casting went "bang" leaving it in bits.
Thankfully he's a smart boy and always had a jack stand or spare wheel under the truck for safety.
I don't think I'll replace it, as I now have a GU Patrol and a new 20ton bottle jack for the job. I certainly recommend that if get one ( or already have one ) be very careful with it, use a jack stand, and have another lifting device as a 'back up".
Capt.
593880
Follow Up By: vk1dx - Thursday, Dec 17, 2015 at 11:08
Ouch
Not worth the worry. Methinks the standard wind up will suffice.
862226
Follow Up By: Batt's - Thursday, Dec 24, 2015 at 17:59
Was that the KCI or the Aldi one you bought thanks.
862477
Follow Up By: Capt. Wrongway - Thursday, Dec 24, 2015 at 20:24
It was the KCI one.
Capt.
862480
Follow Up By: Batt's - Saturday, Dec 26, 2015 at 11:10
Thanks Capt I was contemplating getting one some time but I might stick to getting another bottle jack. I had a KCI 12v ezy wrench for 5 yrs it worked
well I used it a fair bit until it stopped. I decided to try one from 4WD Supacentre which looks identical it lasted a couple of months. They replaced it without any hassle the new one is still working after 6 months but when is stops I'll go back to the KCI branded version.
862502
Reply By: Member - Trevor_H - Wednesday, Dec 16, 2015 at 22:09
I converted a Toyota screw jack that I wind up with a battery drill.
I welded a 1/2" socket to the spindle with the square out. A universal drive fits into that.
My van is a Golf with independent
suspension so the lift point (at the end of the wishbone) is a fair way under so not easy to get to.
I have a 600mm long rod with another socket welded to that to fit into the universal drive.
200mm square plate welded on the base of the jack for stability and so I don't have to have a separate base plate.
The drill has no problem on slow speed lifting the fully loaded Prado.
593884
Follow Up By: Member - Gnomey - Friday, Dec 18, 2015 at 13:54
Good thinking Trevor. Just borrowed part of your idea mate but somewhat in reverse. My screw jack was missing the drive rod with the hook. So I am just back from the shed.
Drive rod cut to my choice of length from RHS (mic says 16mm x16mm), hook made from 10mm coach bolt bent to shape, cut to size and welded into one end of the RHS.
16mm socket fits the other end like a normal nut and turns it nicely. My onboard socket set will do the rest.
Normally rely on a 12t bottle jack but this brings the OE jack back into play as needed.
Cheers and thanks again.
Mark
862248
Follow Up By: Member - Trevor_H - Friday, Dec 18, 2015 at 15:54
Modified Toyota Screw Jack
Split nut is used to position the jack with the rod.
Universal so it doesn't have to be perfectly aligned.
All parts from local pawnbroker.
862256
Reply By: Hoyks - Thursday, Dec 17, 2015 at 18:00
1st up, I always go for safety when lifting the vehicle. At
home it is chassis stands as soon as the chassis is far enough off the ground to slide them under, away from
home the wheel goes under the chassis rail as soon as it comes off. I've had to use jacks to lift a vehicle from flat on the ground once, it wasn't easy as nothing I had was made to go that low, I'm also glad no one was under it at the time.
I'm not a fan of scissor jacks. Manufactures put them in vehicles for 1 reason; because they are cheap. By design they lack strength in all planes other than the vertical and will twist and fail if the load moves.
Even if you have a stand or a tyre under the vehicle for safety, if it moves and the vehicle tips off the jack, 9 times out of 10 the scissor jack will be stuffed and you will be stuck.
I like hydraulic bottle jacks as they are quick to lift and lower the load. If the vehicle moves and falls off the jack they can be quickly re-positioned to get it back. The down side is that they are precision equipment and a bit of dust or grit can see them leaking and not working or a seal can blow and it only useful as a chock and the handles are rather short, so you are a bit too close to being under the vehicle for my liking.
I don't think you can go past the Toyota issue screw bottle jack, they are basic, have long handles so you don't have to get under the vehicle, but if you don't fill them up with sand then there is nothing much to go wrong with them.
593903
Follow Up By: Bob Y. - Qld - Thursday, Dec 17, 2015 at 19:43
Wouldn't disagree with you Hoyks.
I've got a scissor jack in my Falcon
sedan, which I've luckily only needed to use once or twice. But where they are good, as a pair, is to support a
gate, when "hanging" it in a yard, or on a fence line. Infinite adjustment, and with a few minor additions, fill this role much, much better than their intended purpose.
862233
Follow Up By: Hoyks - Thursday, Dec 17, 2015 at 21:13
I've used one to 'adjust' the front wheel arch on a mates car after it had an altercation with a fence.
Stuck it between the wheel and the wheel arch and jacked it out..... then hit it with a hammer.
862234
