2010 V8 landcruiser tray
Submitted: Friday, Oct 23, 2015 at 15:19
ThreadID: 130681 Views:5401 Replies:7 FollowUps:1
Hey guys, I am now the proud owner of a 2010 v8 land cruiser workmate, and the tray I received with the vehicle isn't exactly in great order. Just wondering if trays off any other makes of vehicles would fit it as there aren't many land cruiser trays for sale locally. So what other trays would fit it? If any
Reply By: Member - John - Friday, Oct 23, 2015 at 15:42
Marty McFly like, 2019????????? LOL
John and Jan
AnswerID: 591897
Reply By: mat g - Friday, Oct 23, 2015 at 16:58
Sorry guys, typo
AnswerID: 591900
Reply By: Member - MARIC - Saturday, Oct 24, 2015 at 09:37
Have you tried your closest Tojo dealer, they could put you onto the body builders they use aand presto new tray ;o))
AnswerID: 591910
Follow Up By: Zippo - Saturday, Oct 24, 2015 at 11:50
Indeed the preferred solution. Don't know where the O/P calls home, but the W.A. tray builder for mr tojo is just up the road from me.
FollowupID: 860006
Reply By: AlbyNSW - Saturday, Oct 24, 2015 at 10:23
The dual cab 79 tray mounts are within a bolt hole of a 05-15 Hilux tray and I think the single cabs use the same pattern as the dual
The overal tray size is the same for all utes except the Amarok which is wider than the others
So the main issue is to check the bearer spacing on a tray and then you will need to custom make some leg mounts
The Toyota alloy trays have aa adjustable mount kit but I don't think they will sell it to you unless you have bought an original tray in the first place
The other item to check is the front bar height
AnswerID: 591913
Reply By: Norm C (WA) - Saturday, Oct 24, 2015 at 11:15
The overall general size of trays is mostly the same. (Patrol is different ie: 2000mm wide)
Usually you can modify one to suit another fairly easily.
Be careful when buying one because the head board on a Cruiser / Patrol is
normally higher than a Hilux / Mazda ect.
AnswerID: 591914
Reply By: The Bantam - Saturday, Oct 24, 2015 at 12:46
most aluminium trays regardless of what is printed on the tailgate are universal trays.
"Toyota genuine tray" .... pft ..... its a generic universal tray built undercontract from a local manufacturer and no different to any other.
They are built on a modular system that can be assembled and reassembled to suit pretty much any vehicle of arround the same size.
The traydeck is built of inter.locking aluminium slats, that are bolted to a pair of logditudinal runners.
many of the manufacrurers pre-drill the slats so that the main runners can be installed at a variety of widths.
They then generally sit on 2 or 3 crosswise bearers that bolt to the attachment points on the vehicle.
So as long as it is adaptable aluminium tray, it matters little what it came off.
Even then ...... Hiluxes for example have pretty much retained the same attachment pattern from day 1....... I can not say for certain, bet it would not surprise me if this pattern is in common with the landcruiser.
AnswerID: 591917
Reply By: Bob Y. - Qld - Saturday, Oct 24, 2015 at 14:19
I'd suggest a tray off any Landcruiser ute over the past 20 pr so years would fit your 2010 model, Mat.
I've got a 2015 single cab, and an '02 s/cab here at the moment, and they're the same in width, about 1100mm, between the mounting posts. Just went down and measured them. :-) Be a bit wary of alloy trays if you are carrying extra heavy loads......better with a steel tray.
The tray on my new ute was about $5K plus(made by Rydweld from Townsville, excellent workmanship & paint work) but a 2nd hand one, sans rust 'n extreme damage, should be worth $1500-$2000, maybe less if it needs a "top overhaul". Tried any of the local wreckers? Use of nylon nuts on the mounting bolts seems to keep them tighter for longer too.
AnswerID: 591919
