HI ,
To all ,What are all the different types and brands of batt charger out there that are usefull to members eg to charge a single 120 amp AGM or a twin batt 120 setup.?? Is there any with adjustable amperage ?The preference is for a charger that will work with a 1kv gene .
There are I think whats called power factor corrected types that use less power to run eg u can achieve a higher charge rate with these on a 1kv gene.
Trying to charge around the 20-30% of a/hr capacity of agm or
max 30 amp single and at least 20 amp each for double
Xantrex true charge 20,40 and needs a remote for adjustability lots of dollar 700 plus The remote panel has too be purchased to adjust amperage % 100, 80 ,60,40,20, votage profile is your typical agm flooded gel etc manual dip switch
Blue seas [digital] p12 40 amp The""" most adjustable by far"" but it appears the most expensive
adjustable amps x1amp and voltage adjustable x .05 increments float timer adjustable and amperage absorb trigger point adjustable for when it changes to float .[this allows for fridge loads etc ]
Sterling procharge 20,30,40,50,60 $ around 630 for the 40 amp . The 50/60 amp are very expensive [amp adjustable %100, 75,50,25][has the ability custom voltage profile][lithium ] low pwr usage
Projecta 50 amp does 50 and 25 amp but uses way to much power watts to do this for a 1kv gene
$$ 550 Has seperate volt detection in the charge cable
oz charge 30 amp adjustable for lower amps and low power usage 410 $$
Enerdrive pdf files appear a little incorrect contradict themselves 40 amp $515 Requires a call to Enerdrive 700watts on 40 amp
Can any body add to this eg more selection ,and or ,cheaper prices [we all like that ]
cheers swampy
