damaged vehicle auctions
Submitted: Wednesday, May 12, 2004 at 09:27
choppa
Gday all,
My 89 Cruiser motor needs replacing (2H), I was wondering about the damaged auctions, and about picking up a damaged vehicle ie a later model say a 1HZ model and replacing the running gear over to my cruiser, what sort of money do cruisers pull at these auctions? is this a viable option? I could use some of the other bits ie door trims and such as
Thanks in advance
Reply By: Member - Pesty (SA) - Wednesday, May 12, 2004 at 16:17
Choppa you cheapest option is to rebuild yours espectially if you can do the remove and replace. I did
mine 2 years ago and the rebuild of the motor to 3/4 stage was $2500, and the head full rebuild was $600, Plus I rebuilt injectors and new clutch and bits and pieces less than $4 big ones . The swap for a 1hz is not easy as they are totally different.
The only other option is a second hand 2h, or 12ht which are hard to come by.
58331
