Fridge Slides
Submitted: Sunday, Jun 09, 2002 at 00:00
Ian
hi guys ,was just after some advice on fridge slides ,as to what brands and what prices are around my fridge is a 50ltr waeco ,also will one slide fit all or are there different ones for each brand of fridge ?
thanks,,, Ian
Reply By: kevin - Tuesday, Jun 11, 2002 at 00:00
Ian, I am not sure what state you are in, but I have an Engel, and bought the slide from Snowy's in
Adelaide. It seems to work OK. Try them.
4130
Reply By: Johnno - Sunday, Jun 16, 2002 at 00:00
The fridge slide I use is made by Pirhana, and is resigned for the Engle fridge. It depends on the size of the fridge wether it will fit or not. An alternative is to make one yourself which should save you at least $150.00. All you need is a pair of heavy duty drawer runners bolted to steel angle and a tray which you could make from wood or get somebody to bend one up out of sheetmetal. You will also need a sliding door bolt to stop it sliding forward while travelling. The runners I would use can be purchased from Hafele, and are rated to 100kg. The cat. no. is 420.77.707
4216
