Holden Jackaroo
Submitted: Saturday, Jul 18, 2015 at 18:09
ThreadID: 119528 Views:2214 Replies:2 FollowUps:1
Hi all, I own a Holden Jackaroo 2000 model & with 3.5 Ltr petrol motor.
Where I live it has been very wet but the the other day my wife informed me water was coming in the top of the windscreen on the passenger side.
Then also I noticed the floor on the the drivers side front is also very wet.
I have checked heater hoses etc and the coolant level has not dropped.
Has anyone experienced this & what maybe the cause.
Gazza
Reply By: Member - mechpete - Saturday, Jul 18, 2015 at 19:48
good chance the windscreen is the fault on both counts .
if it was coolant related it would be coloured the same as coolant
so checking hoses is not relevant , unless the A/Cond drain hose has become detached from the heater box
cheers mechpete
AnswerID: 557141
Follow Up By: Michael H9 - Saturday, Jul 18, 2015 at 23:52
I had a wet floor because the AC drain hose was blocked. I could tell because there was usually a puddle under the car where the pipe came out on humid days, then there wasn't and the floor carpet started getting wet.
FollowupID: 843448
Reply By: wholehog - Saturday, Jul 18, 2015 at 20:05
The urethane windscreen bond has let go. Get the windscreen replaced/resealed. most likely replaced, as it will be damaged/cranked getting it out.
Don't just run silastic along the top of the windscreen, as it will entrap moisture and create a potential corrosive environment.
Be wise as to who actually replaced the windscreen, so many fitters end up cutting the paint seal of the windscreen recess with knifes/blades in removing the old urethane seal and then becomes a bare metal environment for future rust development.
AnswerID: 557142
