12volt led van lights dimming
Submitted: Wednesday, Jul 15, 2015 at 23:22
REV'S
Any suggestions on why the 12volts led lights in our van, when on keep dimming then turn brighter while on. I have racked my brain, but still Cann't work it out. What could be done to stop this from occurring? Thanks in advance.
Reply By: AlbyNSW - Thursday, Jul 16, 2015 at 00:48
Is it from when your fridge cycles on / off?
557066
Reply By: Rangiephil - Thursday, Jul 16, 2015 at 09:19
Ditto,
mine do it also, especially when the voltage gets down a bit.
Regards Philip A
557069
Reply By: landseka - Thursday, Jul 16, 2015 at 14:05
Some of my LEDs flicker a lot, is that the same thing?
557072
Reply By: Notso - Thursday, Jul 16, 2015 at 20:56
Probably the voltage. Put a multi meter on it and watch when the lights dim and when they are
bright. It's probably your charger cycling on or off if it's when you are plugged in to 240 volt power.
557083
Reply By: Nomadic Navara - Saturday, Jul 18, 2015 at 11:58
Sounds like there is something cycling on the system. Keep an eye on the battery charger cycling on and off (you pick this by the system voltage rising above 13 V.) Apart from a compressor fridge do you have anything else like a DC water heater for the sink?
557134
Follow Up By: oldtrack123 - Saturday, Jul 18, 2015 at 14:12
DITTO
Very likely voltage voltage changes
PeterQ
843433
