Fins freezing in Frig
Submitted: Thursday, Jun 25, 2015 at 11:40
ThreadID: 119291 Views:1982 Replies:2 FollowUps:0
Our Dometic Fridge in the Van ices up the Right Hand end fins but the left hand end stays clear but cold,is there something we can do to correct this??
Van is level and Fridge also seems to be working all ok, is running at 3-4 deg C at 3.5 on the knob at 4-5 will run 0 deg and under.
Reply By: Member -Dodger - Thursday, Jun 25, 2015 at 16:26
I installed a very small computer fan in the fridge to circulate air across these fins and it has helped the fridge enormously. I wired it in via the 12v circuit with a switch and threaded the wires through the drain hole in the fridge.
There is also a commercial fan available.
Cheers Dodg.
AnswerID: 556332
Reply By: Member - wicket - Thursday, Jun 25, 2015 at 22:32
the fan will help, if you don't want to go to the trouble of wiring one up then you could try one of these, i have one and it's handy and runs for ages on a couple of DD batteries
http://www.campingworld.com/shopping/item/fridgecool-fan-with-on-off-switch/38134
AnswerID: 556349
