Winch rope to drum connection
Submitted: Tuesday, Jun 16, 2015 at 20:05
Member - Kirk L
Hi. I have an ironman winch which I have just rebuilt due to water ingress. I was wondering if anyone has a link or info on tieing the rope back to the drum. It has no holes or bolts or anything to secure rope. It was just wrapped around and threaded through under itself but not sure exactly how it was. Thanks in advance.
Reply By: Mike S2 - Wednesday, Jun 17, 2015 at 09:33
Question sort of relevant,why do the specs of winch say put the rope on drum with overwind and not underwind coiling,cant see the reason for this as motor runs both ways,my winch mount (Nissan gu) does not allow me to fit the unit as o/w so turned it over and fitted upside down to get winch mounted,if it to do with the holding brake the way I have fitted is the same as supplied,cheers,Mike
556068
Follow Up By: gbc - Wednesday, Jun 17, 2015 at 10:57
Powering out on a lowmount generally works against the brake and creates enough heat to melt synthetic rope = unpreferred outcome.
842184
