12 Pin trailer plug - keeping it secure
Submitted: Thursday, Jun 04, 2015 at 14:15
outback epicurean
Just replaced the old 7 Pin plug with flat 12 pin unit (New van!). In the past, I have always used an elastic band to keep the 7 pin cap in place around the unit and stop the plug rattling out on corrugated roads (learnt the hard way!).
Just wondering if people have had any similar issues with the 12 pin units and any simple ways to stop the plug rattling out. Very smooth main unit and hard to secure an elastic band around the 2 halves.
many thanks
Reply By: Sand Man (SA) - Thursday, Jun 04, 2015 at 14:55
I have been using a flat 7 pin socket/plug combination for years without any problem.
The spring loaded cover includes a couple of lugs that when opened and the plug inserted, provides a mechanical locking arrangement.
Actually, I lie!
Have had the plug exit the socket on one occasion when I hit a washout and smashed the socket to bits.
It's in a bugger of a location and I just have never got around to moving it:-)
554565
Reply By: vk1dx - Friday, Jun 05, 2015 at 09:27
Similar response to others above. We have never had an issue with our metal pair. The spring loaded lid on the socket sits over some extrusions on the plug.
I also keep it clean by hosing it with a strong jet, even when not used. Maybe dust is the lid hinge or spring is the problem.
This is a very similar pair on ebay (Item#: 321519121469):
554586
Reply By: Kenrconn - Friday, Jun 05, 2015 at 11:10
I too, have never had a problem with the 12 pin flat plug. BUT
mine has a cover on the plug that is hinged to it opens horizontally and will go down the side of the socket and lock on to the socket. It also has the cover to the socket which is hinged and opens vertically. This then locks on to the top of the plug and holds that in place as
well. The only problem that I have had is with the rubber boot on the plug not being long enough or flexible enough to allow the wires to manouvre. This was fixed by the used of silicone tape. The new WONDER-HELPER to all travelers.
554594
