12 volt electric blankets
Submitted: Sunday, May 31, 2015 at 14:52
ThreadID: 119052 Views:2892 Replies:4 FollowUps:2
G'day all, Looking for any info regarding a single bed electric 12 volt blanket for our caravan. Looking on line I note that there are a range of "travel or throw" blankets for in car use but I need an under sheet unit .I have found a site "Tek Trek" that advertise what looks to be what I seek. Is anyone familiar with this product or has any knowledge of any other alternatives and where to source them.
Thanks to any who care to replyjohn y
Reply By: Member - bungarra (WA) - Sunday, May 31, 2015 at 15:16
Wouldn't bother with a 12 v
We have a standard 240v blanket that we use through the inverter for 15 - 30 mins and it prepares the bed very efficiently.............after that we shut it down.....I guess we could run it all night but never bothered
If you check the wattage on a blanket they draw surprisingly minimal current.....and as far as being cost effective goes have a look at the inverter option if your set up lends itself to that
VKS 1341
AnswerID: 554470
Follow Up By: Mike S2 - Monday, Jun 01, 2015 at 10:59
X2 for the 240v option with inverter
FollowupID: 840580
Reply By: johno59 - Sunday, May 31, 2015 at 19:14
John, Google the 12 volt shop. Am sure they stick them johno
AnswerID: 554475
Reply By: Member - Scott M (NSW) - Sunday, May 31, 2015 at 19:25
check this out
http://www.mycube.net.au/
http://www.mycube.net.au/index.php?item=PriceList
AnswerID: 554476
Follow Up By: Member - john y - Monday, Jun 01, 2015 at 21:16
Thanks for the input . have decided to go with the 240 volt option. regards john y
FollowupID: 840598
Reply By: pmk03 - Thursday, Jun 04, 2015 at 16:01
Think outside the square ........
Been using hot water bottles for years, Boil the kettle with gas & your done.
Cheap & easy & doesn't drain your power supply.
AnswerID: 554567
