Altitude profile?
Submitted: Monday, May 04, 2015 at 15:33
ThreadID: 117728 Views:1936 Replies:6 FollowUps:1
I have been checking various routes to see which is steepest etc using Treks, adding start and end points, getting the route, then asking for a gradient profile. The maximum gradient shown changes on the same piece of road depending on how much of the route I enter. For example, I am trying to find the gradient of Mt Ousley NSW compared to Bulli Pass. If I enter my complete trip of, say 150kms, the gradients shown are different to when I enter a short trip just covering the base of the hill to the summit. What am I doing wrong?
Reply By: Member - Gary R M (VIC) - Monday, May 04, 2015 at 16:57
G'day Kenham, if your total change in altitude is say 1,000 metres (1km) over your 150km journey then your average gradient for the whole trip would be 1 in 150 whereas if say the change in altitude from the bottom to the top of the hill is say 200m (0.2km) over a distance of say 4km then the grade specific to that section of road would be 1 in 20.
I've only made up these numbers as I'm not familiar with the area but hope this helps.
Regards, Gary M.
Gary M
AnswerID: 553295
Reply By: Kenham - Monday, May 04, 2015 at 17:21
Thanks Gary, I understand what you are saying but it's not really what's happening. When I ask for the gradient profile it gives the whole trip as a graph and indicates the precise point of the steepest section, both up and down, with the gradient as a percentage. A 30% gradient, I assume, would rise 3 metres for every 10 metres horizontally - very steep - but only at that specific point. Problem is, when I enter a start and end point covering just that particular hill, it gives a different % gradient to when I enter a longer trip including that hill. That sounds very clumsy but I don't know how else to explain it. For instance, if I enter Wollongong to Sydney, it shows the steepest bit as a certain percentage but if I enter just that steep bit, the percentage is different. Hope that makes sense.
AnswerID: 553297
Reply By: Member - Gary R M (VIC) - Monday, May 04, 2015 at 17:37
Hi again Kenham, I've never used Treks so probably can't help further. If you had access to a topographical map of the area you could estimate a gradient using the contours and horizontal distance but that's about all I can offer.
All the best, Gary M.
Gary M
AnswerID: 553302
Reply By: ExplorOz Team - Michelle - Tuesday, May 05, 2015 at 15:46
HI Kenham, I've just been trying to catch up as we have been away and just noted your query. Having just had a quick chat with David about this, he confirms that the linear accuracy in the data is restricted by the number of points in the file. To get the most accurate result, use a short distance. Hope this helps.
Michelle Martin
Marketing & Customer Support
AnswerID: 553352
Reply By: Kenham - Friday, May 08, 2015 at 15:48
Thanks Michelle,
Perhaps I don't understand what gradient percentage actually means. I'm trying to simply find out what is the actual steepest part of a route I am planning as I tow a rather heavy caravan.
I am in Sydney so perhaps I could give an example. I wish to choose between Mt Ousley and Bulli Pass when travelling north from Wollongong. The Mt Ousley route, which I know and use often, has not just one climb but 3 or 4, meaning you go up a steep hill and down the other side 3 or 4 times but Bulli Pass has just one hill but it is, I think, a bit steeper. I want to find out, just how much steeper is it?
If I enter a route from south of Mt Ousley to a bit north of Mt Ousley, the gradient is shown as a certain percentage but if I enter a much longer route, say Nowra to Sutherland, The gradient at the same point on Mt Ousley is shown as a different percentage. That's what I don't understand. Surely a gradient is always the same percentage? It's always possible I am doing something wrong as well. Ken
AnswerID: 553444
Follow Up By: Nomadic Navara - Saturday, May 09, 2015 at 23:17
I think what Michelle was indicating is that the spot points are further apart in the longer trips you enter than the shorter ones. With the longer trips the distance between the points are longer so less accurate.
Take notice of the shorter lengths you select and disregard the longer ones.
FollowupID: 839389
Reply By: Kenham - Sunday, May 10, 2015 at 11:46
Thanks Peter for your reply. I am still confused. I am after the steepest point and just how steep is it. I don't see how the distance of the route comes into it. Surely the steepest point is always in the same position and always the same grade regardless of how long the trip?
AnswerID: 553535
