Saturday, Apr 04, 2015 at 16:07
Allan,
I prefer to go to the horses mouth as I don't believe a blanket statement in the IEEE can be applied to all alternators.
Hi have discussions with the technical design persons of three of the major players, regarding if their alternators are designed to supply the nominated rated output continuously ie longer than 10 minutes duration etc.
Two responded with their alternators are not design to produce their rated output on a continuous basis and should be derated by 20% to 30% under reasonable ambient conditions and operating conditions, following from Denso:
"Leigh,
It will be specific for each DENSO Part Number or application, hyowever, 75% of "rated amps" will generally be OK for continuous operation. "
You have already read the reponse from Bosch, I have had quite a few discussion with them over the past and the only time they will guarantee continuous 100% ouptut is in a free airflow of 25C where the alternator can shed its heat load and this is not going to be the case in a typical vehicle setup, another guote from Bosch:
"Hi Leigh,
I can only comment on Bosch .
An alternator supplies it’s rated current at standard test conditions (25deg ambient @ 13.5V) after a stabilization period, this stabilization period however does capture conditions before they rise to maximum. Windings have an PTC characteristic, diodes an NTC, PTC dominates the losses. It would be not practical to remove all heat loading to maintain the internal test temperatures.
Obviously we need to lock in a standard test procedure, else do you test after what time, what load, what temp, what voltage etc. Alternator temperatures rise at very high output and if an equilibrium point is reached (before damage) then it is very high. Duty cycle in use are infinitely variable and all external influences are a factor, therefore a meaningless metric in the real world if we were to test at a set ratio.
“100A max / 50A continuous, 50% duty cycle”- what time at max?, what time at 50A? (i.e., total time of test period?), voltage deviation due to regulator temp compensation effect on output? Tests period adjusted to a target rectifier temperature? same test periods for all alternator type, range and user application? I can think of many variables that would give me a figure that still requires me to confirm my application in real world testing.
In practice temperatures rise to various levels as subject to differing conditions and to so it is an important consideration. We have seen 190deg rectifier temperature on one local built vehicle with poor air flow design on hot days!"
Three of the main players including the supplier to Toyota all state you need to derate under haevy loads and continuos operation and all also state that is is indeed possible to overload their alternators so i think I'll go with the alternators manufactures in this instance rather than the IEEE:)
837556
