EXPLOROZ,Windscreen Sticker
Submitted: Saturday, Mar 21, 2015 at 14:04
ThreadID: 117152 Views:1861 Replies:6 FollowUps:8
What's the best method used to put it on straight ,cheers GD
Reply By: Member - mark D18 - Saturday, Mar 21, 2015 at 14:16
Greendog
Check your local tech college for relevant the course .
AnswerID: 551332
Follow Up By: Member - mark D18 - Saturday, Mar 21, 2015 at 19:46
Greendog
Sorry I thought you were only joking.
I thought you were talking about the little round explore Oz sticker
FollowupID: 836826
Reply By: TomH - Saturday, Mar 21, 2015 at 14:30
Get a litre of water in a spray bottle Put a desertspoon of dishwash liquid in it.
Spray both the screen and sticky side of sticker with it.
Put on windscreen and get in position and scrape a credit card or similar straight thing across to expel the water and it will stick.
If you want to be fussy after getting it in place you can spray diluted isopropyl alcohol under one end to tack it and then use the credit card. That makes the water disperse and allows it to stick.
Thats how you put vinyl wrap on.
Have done my bumpers and door sills with 3M wrap like that.
AnswerID: 551333
Follow Up By: member - mazcan - Saturday, Mar 21, 2015 at 16:31
as above or you could let some air out of a couple of tyres ??
FollowupID: 836813
Follow Up By: TomH - Saturday, Mar 21, 2015 at 22:22
What exactly has letting tyres down got to do with putting stickers on a windscreen
FollowupID: 836831
Follow Up By: Zippo - Sunday, Mar 22, 2015 at 13:20
Helps to get it level ....
FollowupID: 836863
Follow Up By: member - mazcan - Sunday, Mar 22, 2015 at 13:24
TomH
if i have to explain that you obviously don't have a sense of humour
the op asked how to get a sticker straight when placing it on the windscreen i said as above referring your advice or let some air out of a couple of tyres which will tilt the vehicle and straighten the sticker
you need to lighten up laughters good medicine
FollowupID: 836864
Reply By: Bob Y. - Qld - Saturday, Mar 21, 2015 at 15:05
David has a "How to" video on the page for the sticker, in the shop, Greendog. Bit hard to hear, but you'll get the drift. He doesn't root around with spray bottles, as I would have suggested, but just uses a sponge, soapy water and an EO members card.
Might just pay to mark the centre of screen beforehand, so sticker looks even. Otherwise looks pretty straight forward.
AnswerID: 551335
Follow Up By: GREENDOG - Monday, Mar 23, 2015 at 19:58
Thanks Bob ,just done exactly that ,cheers GD
FollowupID: 836946
Reply By: Fab72 - Sunday, Mar 22, 2015 at 09:18
I run two strips of masking tape across the windscreen at the top extremity then another at the lower edge leaving enough space between the two parallel runs of masking tape to fit the sticker in.Check the area is straight, clean etc.
Measure the overall length of the sticker, divide by 2 to find your half way point.
Then mark the masking tape to show your half way mark of your windscreen, measure back to find your starting point and away you go. Keep it between the tape and smooth out air bubbles as you go using a ....wait for it..... a candle. The candle won't dig into the sticker and tear it yet is hard enough to push out the air.
Remove masking tape....wash away any residue and bingo.
Fab.
AnswerID: 551373
Reply By: The Explorer - Sunday, Mar 22, 2015 at 12:23
...nobody told me they were for your window..
AnswerID: 551385
Follow Up By: ExplorOz - David & Michelle - Tuesday, Mar 24, 2015 at 21:33
I have one on the boat - slightly modified but the same principle.
FollowupID: 837008
Follow Up By: The Explorer - Tuesday, Mar 24, 2015 at 21:39
You could have zoomed in a bit.....looks a bit dry :)
FollowupID: 837009
Reply By: GREENDOG - Monday, Mar 23, 2015 at 19:59
Thank you for your posts ,jobs done
AnswerID: 551494
