suction caps
Submitted: Sunday, Mar 15, 2015 at 15:16
Member - Des Lexic
G'day all, I'm trying to source some suction caps to use to hold insulated screens onto the windows in the back of the wagon. The type I'm after have a clip that fits over the suction cap which secures the screen to the Window
Ebay hasn't been able to assist as I don't know their correct name.
Thanks for your help.
Reply By: Member - Tony F8 - Sunday, Mar 15, 2015 at 16:00
Try clark rubber, I even think you can order them online from clark rubber to.
550016
Reply By: Bob Y. - Qld - Sunday, Mar 15, 2015 at 16:27
Seem to be like rocking horse poo, Des! :-))
Doesn't appear to be anything at the rear of the sausage sizzle stand, but did find something from a firm in NSW.
Pic below:
Suction Cup Selection
No affiliation with this mob,
I needed to make a sunshade for bottom of windscreen in a truck when heading into afternoon sun. Nothing worse than sweating, in the cab, with aircon going flat out! Cut a
sedan sized one to size, added some eyelets as needed, and used the supplied suction cups, plus a couple off a worn out sunshade. But I get the feeling you might need more than 3 or 4?
550018
Follow Up By: Kazza055 - Sunday, Mar 15, 2015 at 17:29
I have thought of doing a similar thing using clear sheeting from bunnings. Could possible use the "suction pads SR1691" shown above and use a key ring or something similar to keep the sheeting from pulling through.
You would need a few of them probably about 100mm apart.
835417
Follow Up By: member - mazcan - Monday, Mar 16, 2015 at 10:51
hi
as above
kelvindale products pty ltd
www.essentracomponents.com.au
or you could try clarke rubber
835468
Reply By: thephantom - Sunday, Mar 15, 2015 at 17:45
Hi Des Lexic
Sounds as though you have screens supplied by solarscreen.com.au or something similar. We have them and when we needed some extra suction caps I contacted them through their web site and had a good number sent out at the one time as, from memory, there was a fixed price postage for one set (of 3 caps I think) or ten sets. Here is the web site:
http://www.solarscreen.com.au/
Hope this is of some help to you.
550021
Follow Up By: Michaeljp - Sunday, Mar 15, 2015 at 19:01
I recently bought a set of rear screens and the front windscreen one 8" high from solarscreen. great quality.
835425
Reply By: Michael ( Moss Vale NSW) - Sunday, Mar 15, 2015 at 21:15
Find companies that deal in glass craft & leadlighting
home craft type of
places. They have them in two sizes usually. I use them for holding my rear windscreen polycarbonate covers on when towing. $0.80ea Michael
| Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.Member My Profile My Blog Send Message |
550033
Follow Up By: Member - peter w2 (VIC) - Monday, Mar 16, 2015 at 16:07
Spotlight will have them
835493
Reply By: Member - Rosco from way back - Monday, Mar 16, 2015 at 21:27
Repco. Buy a couple of there cheapas sun screens and reuse
the cups.
550078
Reply By: Sigmund - Wednesday, Mar 18, 2015 at 16:07
Clark Rubber apparently have more types in stock than are shown on their website, inc those with a threaded stem and knurled nut. If you want these and CR can't help try an aquarium supplies place.
551163
