Friday, Mar 13, 2015 at 17:37
Ben,
Looking at the M300 Owners Manual, it appears this charger does not have a supply mode. Therefore it is not suitable to run the fridge unless both are connected to the battery. Additionally, trying to charge a battery with a high-drain appliance like a 3-way fridge (12-15 amps) connected at the same time is not very satisfactory. So installing an inverter to run the M300 is not the way to go in my opinion.
Given the two Andersons on the camper, if I was doing it this is what I would do: I would install an Anderson at the back of the tug, and make or buy an Anderson double adapter to power the two Andersons to your trailer. I think the best way to charge a camper or caravan battery is with a DC-DC charger located in the camper near the target battery. The DC-DC charger can make up for the voltage drop encountered in the long cabling from the alternator and still provide a tailored charge to suit your camper battery.
So one trailer Anderson would power the DC-DC charger. Depending on the output of the DC-DC charger the supply cabling in the trailer for that should be 6mm, but preferably 8 B&S. I assume the other trailer Anderson that goes to the fridge goes directly to the fridge's 12V input.
Check the cabling - it must be AT LEAST 8 B&S (=8AWG, =8 gauge. NOT 8mm). If it is not, then re-wire it.
This is because for the fridge to work on 12V the 12V supply MUST have minimum voltage drop under load and the only way to do that is with big cable. You need 12V or more UNDER LOAD at the fridge. Small cable won't hack it. You need an Anderson at the back of your vehicle. That must be cabled with AT LEAST 6 B&S for the reason stated above - ie to minimise voltage drop in the supply to the fridge. You should also use an isolator of some kind (VSR or ignition-controlled "dumb" solenoid) so that when the engine is off the supply to the camper is off. This will prevent the fridge running your crank battery flat when you go to buy your supplies.
Yes, you could just unplug things, but the first time you forget you will rue the day you decided to skimp. Make up or buy an Anderson double adapter so that you can plug it into the back of the car and have two Anderson outlets.
One will go to the fridge, the other to the rest of the camper and the DC-DC charger. If you make your own Ando double adapter, for practical reasons use 8 B&S (it's only a short cable run, maybe just a few inches, up to you), the 6 is too hard to do tight bends and you won't get two cables into one terminal.
(See the photos to get an idea of what I mean.)
As others have mentioned, you can get Ford to de-activate the
Ranger's smart (ie low output) charging system. This would definitely be better for the fridge and would be my recommendation for practicality and simplicity. Also mentioned elsewhere, Redarc make low voltage versions of their DC-DC chargers for vehicles like the
Ranger, so you could try an unmodified charging system. If it works,
well and good. If it doesn't, get it switched off.
549922
Follow Up By: Ben M10 - Friday, Mar 13, 2015 at 18:05
To utilise a AC charger then I was thinking option 2, which requires a inverter. Not sure if this is an option??
835309
Follow Up By: Member - John and Val - Saturday, Mar 14, 2015 at 09:04
Ben,
Frank has covered the subject very
well. One thing I'd add - personally I'd run two heavy cables from the engine bay to plugs at the towbar, rather than a single one to be shared by a double adapter. This will cost cable, but minimize losses and so improve performance of both fridge and dc-dc charger.
Unless you have other reasons to carry an inverter I wouldn't have one in the rig. Certainly taking 12V up to 240V and then down again to 12V is a horribly inefficient way of getting back to where you started!
| J and V
- Albert Einstein
835336
Follow Up By: Frank P (NSW) - Saturday, Mar 14, 2015 at 09:11
Thanks, Mods, for the repair work :-). Much appreciated.
Ben,
IMO option 2 is not a goer. I don't think the M300 has a supply mode. It's geared only toward charging a battery, not supplying a load. There are other chargers that DO have a supply mode - one of those might work. But then you can't charge the camper battery AND run it in supply mode at the same time. You COULD if you ran two chargers, one in supply mode driving the fridge, one charging the battery. Getting a bit OTT, I think. Better going the DC-DC charger route, IMO.
Here are the promised photos:
Double adapter detail
835337
