Comment: How to Settle Muddy Water
Good reading Steve and interesting results.. as it is only for showering the cook and I don't bother. we can go a few days (last trip 9days no shower) but a sponge bath will do the job as we both smell the same, or a swim in the river is even better. The idea is good if you are running low on drinking fluids. We have used an old stocking folded several times, to filter the larger fines then boil for drinking as well as purifying tablets. But no should never run that low on drinking water anyway. Another idea for drinking water if you are stuck is to dig a hole place a receptical in the centre cover the hole with clear plastic with a small stone in the centre to form a slight low point. place your fines around the outside of the plastic to form a seal and evaporation will do it's job, even at night. Not lots of water, but is better than none - Garry R
location - Warragul -Victoria
