Hi Ian.
I have had a Cobb Cooker for about 5 years and they are great. Mainly I use
mine to
cook roasts (Chicken, Lamb, Beef etc) as
well as cakes and scones.
I always use the Cobb stones (Fuel) except if I am cooking scones on their own. 6 heat beads is enough for scones. The Cobb Stones last around 90 minutes which is plenty of time to
cook a roast for 2, including all the vegies. There is one word of caution and that is to
cook out of the breeze. If it is windy, you need to set up a wind break otherwise your meal will
cook extremely slowly or not at all on the "up wind" side.
I also have a small
camp oven which will fit inside the cobb and sit on the fire basket. This is great for cooking casseroles and some deserts. It will also fit on top of the normal cooking plate under the dome although I did have to buy the dome extension. I cannot remember how much that cost but it was not that dear. The
camp oven can them be used to
cook your roast and it is much easier to clean than the cobb cooker.
The
cook book that comes with the Cobb says to put water in the moat. I have tried this and it does not make much, if any, difference but give it a try.
Other than that, just use it to
cook anything you would normally
cook in your normal oven at
home. Experiment away and you will not be disappointed.
Regards,
Michael
