salt water in porta potties
Submitted: Sunday, Mar 21, 2004 at 21:06
friar
Hi all
Has anyone used salt water in a porta pottie
Friar
Reply By: Willem - Sunday, Mar 21, 2004 at 21:33
Dunno....might rust your bum :-)))))
Not sure if the chemicals which you have to use will mix with the salt water.
If you are not using a chemical it may do for a stopgap situation(no pun intended)
51317
Follow Up By: Member - Brian (Gold Coast) - Sunday, Mar 21, 2004 at 21:47
Willem,
ROTFLMAO
313034
Reply By: Member - Anne - Sunday, Mar 21, 2004 at 23:34
Dear Friar,
Forget the Porta Potty - nasty environmentally unfriendly, difficult to dispose of chemicals etc. Buy a Thunderbox!
Anne
51334
Reply By: guy (sydney) - Monday, Mar 22, 2004 at 07:51
If you use salt water in a urinal you run the risk of getting a buid up of a gas called H2S (rotten egg gas) very bad. You need a couple of things to get it one is human waste another is salt water and the other is a not very ventilated space.
Too much of a risk for my taste. This gas kills as
well if you take in a small amount.
Im not talking from experience with porta poties only ships and there sewage system.
Guy
51349
Reply By: Glenno - Tuesday, Mar 23, 2004 at 21:04
There was a post reagrding this in the archives. I think the manufacturer of the Haymen Reece chemicals said it worked OK for fresh or salt water.
For short trips where we dont need to empty the potti on the road, I have an access point to the sewerage pipe in my front yard. Its about 100mm wide and has 8 screws in it. Easy to undo and pour the conents in. Saves splashing crap all up the dunny walls, or finding a spot out in the bush.
Glenno.
51643
Reply By: friar - Wednesday, Mar 24, 2004 at 03:29
Thanks Glenno
51720
Reply By: Halceon - Thursday, Apr 01, 2004 at 16:55
Friar,
I have used it salt water many times without an issue.
52834
Reply By: friar - Thursday, Apr 01, 2004 at 18:14
Thanks Halceon much appreciated for your information
52850
