Hints & Tips
Submitted: Friday, Mar 19, 2004 at 22:41
ThreadID: 11397 Views:1833 Replies:3 FollowUps:4
Forumites,
Took part in the club sand gymkhana last weekend and during one of the events the Rangie developed a bit of a missfire, checked all the usual stuff, couldn't find anything, plug leads, compression test etc etc anyway found the two center plugs RH bank a tad darker than the rest, so I replaced all the plugs they looked due and they where Boshe (nuff said), had the choice of some NGK Iridium plugs at $22 a pop it gets expensive with an eight cylinder mind you they do last for 80,000 klms so they would save in the longer term, anyway, so I went for the standard NGK good enough for now, missfire was a lot better but still not perfect, couldn't find anything else. I waited till dark, started the engine and popped the lid, found the problem straight away, the two centre leads whre arcing through the dipstick every now and again, hence the missfire, I bent the dipstick slightly down and it's now perfect again. Just a hint / tip it's always worth looking for electrical problems in the dark, it's a regular little light show. Hope this helps someone else.
Keep the shiny side up
