Comment: Toyota Wheel Studs - Replacing the standard 78/79 series studs with cus
Good write up, but i will go out on a limb and say it is very possible it was not the "gap" that caused it, yes there will be people out there with far more experiance than me but it is common to have that "gap", you will also find some rims dont seat tight on the hubs in the center and rely completely on the taper of the nuts to hold it in place, with six nuts/studs clamped up to tension there is a fair bit of pressure applied the the faces and it should hold it all in place, the only way it could wear like that is i would say a faulty rim .... anyway it sounds like you will have an even better system now so it is good..
Joe
