Passing cable through Jackaroo firewall
Submitted: Tuesday, Mar 09, 2004 at 22:40
Savvas
Hey all you Jackaroo owners...
Where's the best point to pass wiring through the firewall and into the passenger cabin?
I have tried to get some wiring through the large rubber grommet where the major cabling loom goes in next to the brake master cylinder, but that is sealed up really
well and I'm not overly keen on cutting my through it.
I want to get wiring for a driving light switch and UHF aerial through.
Reply By: Member - Bradley- Wednesday, Mar 10, 2004 at 10:39
easy large grommet on pass firewall, make some grommet pokers as
well ( various size pieces of pipe whith a chamfer on one end , start hole with a sharp point, some silicon etc. on chamfered end and she will glide on through, leave in position while you run the wires stress free without risk of dislodging the grommet , and remove and slide off cable on free side when finished.) i have always used these especially when doing stereo installs as you can run 4 guage cable etc. easily. Showed the guys at holden how to make em, they were amazed as they had never seen it before and always cursed running wires. we ended up using the broken stainless aerial masts for small cables.cheap and easy, cheers...
49755
Reply By: Roachie - Wednesday, Mar 10, 2004 at 11:08
Savvas,
The only way is through the rubber grommet/s.
I hepled a auto-sparky mate of
mine install heaps of gear on my GU when I got it in 2000. He had a great little gadget to assist with this. It was like a very thin cone-shaped metal funnel thingo........the narrow end came to a sharp point and the other end was about 30mm wide; it was about 7" long. It had an open slit right up it to allow cables to be inserted and for the tool to be removed after the job was completed. I'm not sure if it's something that is available from a auto-electrician's supplier etc.
He pushed it through the grommet and then was able to thread through the necessary wires/cables all at once. Made the job soooooooo easy. I always have to use a piece of coat hanger straightened out with a squashed-over hook at one end to get my cables through.
Good luck,
Roachie
49759
