wind up jack stands for ute canopy
Submitted: Thursday, Feb 19, 2015 at 22:32
dermie66
I'm in the process of designing a canopy for the ute tray and am working on a system to remove the canopy from the ute when not in use. The canopy
shell will weigh approx 300kg total and the floor will only have moderate re-enforcing so will be lifted off "empty". I was hoping to use wind up legs as pictured in the link below but was hoping to find legs with a wheel instead of a foot so the canopy can be wheeled around the carport.
http://caravansplus.com.au/catalog/product_info.php?products_id=12873
I know there are cheaper deals than the one in this link but this was just a good example image.
Has any one come across a wind leg with wheel rather than a foot plate and where might I get one? Thanks in advance.
Reply By: Mick O - Thursday, Feb 19, 2015 at 22:46
I use a similar product for my ute canopy but am unsure of the price. They are heavy. I've had the handles cut off and welded a 1/4" socket fixture. This stream lines them somewhat. Casters you may have to source and fit yourself.
Mine were sourced through Marco at Allform engineering in Morwell. I'm not aware of the price and it is some four years ago. Give him a ring and I'm sure he will steer you in the right direction. Contact numbers in link below.
You will need to ensure that you have a double fixing point on the canopy and that they are very
well reinforced, particularly if using Aluminium.
Building the dream off-roader
Cheers Mick
546213
Reply By: Batt's - Friday, Feb 20, 2015 at 00:05
They look ok .I'm going to do
mine the lazy way later on replace the rear coils with air bags attach legs to canopy then lower it and drive away I saw a video once with a fellow demonstrating it and that convinced me it was what I needed.
546219
Reply By: Member - Tony H (touring oz) - Friday, Feb 20, 2015 at 01:04
Hi Dermie,
If your ute has a tray & not a tub & your designing/building it yourself. Consider something like this a lot cheaper & very easy to use, slip the pipe in, slide the A frames onto the pipe & then drive off, to to refit simply reverse back on to it... then secure to tray.
Look at these links you should get the idea......
http://www.gumtree.com.au/s-ad/warragul/heavy-farming-agriculture-equipment/cattle-crate/1070181320http://www.gumtree.com.au/s-ad/warragul/heavy-farming-agriculture-equipment/cattle-stock-crate/1070871091
546225
Follow Up By: member - mazcan - Friday, Feb 20, 2015 at 21:57
hi
they are called hobb hoists
834013
Reply By: alhow - Friday, Feb 20, 2015 at 08:19
I paid $99 each for
mine with the foot from Wang Bearings. Try trailer makers and bearing
services.
I also removed the crank and welded on 19mm nuts. I also welded a socket to a crank handle in case of a flat battery with the drill.
546236
Reply By: Bob Y. - Qld - Friday, Feb 20, 2015 at 15:54
Dermie,
Bloke that made our canopy supplied a set of 4 "homemade" legs, as part of the initial cost.
Camper Leg
If you want wheels, then go to Bunnings. They have castor wheels in various sizes, and am sure you'd get a set to match weight of your camper. You just need to bolt the c/wheels to the base plate, and all good.
FYI, the floor of our camper sits on about 5 of 75 x 50mm RHS, and this keeps the floor rigid, as
well as giving an air space above the tray. Could post some photos if you're interested?
546267
Reply By: dermie66 - Saturday, Feb 21, 2015 at 09:42
Thanks very much for all the replies and suggestions, much food for thought.
Many have previously told once you put the canopy on you'll get sick of taking it on and off, I don't plan to be taking it on and off when touring, in fact I wasn't even planning to take the legs. But I do need my tray space for day-to-day stuff when at
home. Problem is I no longer have access to a work
shop or any sort of lifting gear that was part of my original planning.
The $1000 price tag to jack it off always concerned me too so thanks again for your input. I'll post to the
forum whatever the final product is.
546298
Follow Up By: Member - johnat - Saturday, Feb 21, 2015 at 17:19
Went down that track earlier, and came to the conclusion that it was more effective to use a chain block, attached to the garage roof truss. It only needs to be used to put the "pod" on when we want to go away, and remove it for storage (on a bank of old tyres) when we return.
We also need to use the tray of the ute for other stuff during the workaday, so the work involved in getting the thing on/off is no biggie!
834071
