problems with 2010 pk ford ranger
Submitted: Saturday, Feb 14, 2015 at 15:57
ThreadID: 111113 Views:25773 Replies:4 FollowUps:9
i'm looking at buying a 2010 pk ford ranger and just wondering if anyone who has owned one knows of any problems or faults that they have
thanks
Reply By: Matthew G3 - Saturday, Feb 14, 2015 at 16:37
Hi Jason
If your looking at a manual they can be a bit cluncky. If the same as the PJ they run AUTO fluid in the manual box, I change mine ever 30k and I don't do any towing only a 6x4. If you run normal trans oil they do seize. After about 30k the fluid is a dark plum colour better safe than sorry.
matt
AnswerID: 545918
Follow Up By: Member - DW Lennox Head(NSW) - Saturday, Feb 14, 2015 at 17:43
I had a Mazda BT50 2010 model which is almost identical to the PKRanger. I have done a few things to it but do not experience any of the problems Matthew G3 speaks of.
Mine has done 75,000 kms. Is regularly serviced by a 4 WD place and not dealers. It has towed a 1900 kg Kimberley Karavan for at least 50,000 kms
I have replaced the clutch with a solid one and ditched the dual mass one it was fitted with.
The front wheel drive now has a switch that can disengage the front diff and so enable L 2WD to be used for reversing. Both diffs have extended breathers to inhibit water ingress.
There is a 125 litre Longranger fuel tank in place of the original along with a Safari snorkel. A dual battery system is also fitted. A 10 l air tank is fed by an ARB compressor mounted inside.
Basically, I am very happy with my BT50 and am about to set off on another long trip dragging the Karavan.
FollowupID: 833589
Reply By: jason e1 - Saturday, Feb 14, 2015 at 21:28
Thanks for the reply it's a bit concerning if they run auto fluid in a manual transmission the one I'm looking at has 140000km manual poverty pack
AnswerID: 545935
Follow Up By: Hoyks - Saturday, Feb 14, 2015 at 22:36
Many manufactures run ATF in the box. I had a Nissan that left the factory with ATF in the gearbox and gear oil in the transfer case.
You could run either according to the manual, I ended up going with gear oil as it was one less bottle to buy.
But those mechanical and automotive design engineers, what would they know?
FollowupID: 833609
Follow Up By: 671 - Saturday, Feb 14, 2015 at 23:24
" it's a bit concerning if they run auto fluid in a manual transmission"
Why? Both boxes are full of steel gears. I agree with Hoyks, ATF has been used in many manual boxes and so has engine oil.
All you have to do with any car is use whatever oil and grease the manufacturer specifies and it will work. The time to try something different is when you know more than the engineers who designed it.
FollowupID: 833611
Follow Up By: jason e1 - Sunday, Feb 15, 2015 at 08:02
i have been doing some research and they run a full synthetic gear oil 70-75 viscosity so it's closer to auto fluid than gear oil.
hoyks i have just sold a nissan and would not go near one again they are rubbish
FollowupID: 833616
Follow Up By: jason e1 - Sunday, Feb 15, 2015 at 10:46
671 actually auto and manual transmissions are very different automatic transmissions are part hydraulic pump part gear box that's why they run auto fluid it's much lighter and can get pumped around easier
I have not stated in any of my comments that I know more then mechanical engineers
I said it was concerning in that the servicing cost will be higher as the oil will need changing more often
Having worked for almost 20 years in very remote areas around trucks heavy earthmoving equipment and vehicles fixing and servicing them all I have seen what happens to oil in high temperature heavy load conditions
I asked a simple question and if you don't have a constructive comment to make don't comment
FollowupID: 833626
Follow Up By: Ron N - Sunday, Feb 15, 2015 at 12:53
The Mazda manual gearboxes (and the Ranger is basically a Mazda - it's called badge engineering) are like most Japanese 4WD manual gearboxes - finicky, highly stressed, and prone to expensive problems.
They are tightly engineered with very close tolerances and lightweight bearings, and especially needle roller bearings - particularly the needle roller where the clutch shaft fits into the mainshaft.
Many of these gearboxes require special oils, specifically designed to improve lubrication to these heavily-loaded bearings and to improve gear shifting ability.
In addition, these gearboxes run very hot under high speed and heavy towing applications, because the amount of oil they hold is barely minimal - and therefore the oil should be changed in them frequently.
Many owners think they should never have to change gearbox oil, thinking from the days of old Holdens and Falcons when a gearbox fill was for life.
However, Jap manual gearboxes behind diesels, need to be treated with care - regular oil changes (which also enables you to see internal damage appearing, by examining the oil drained) - no heavy towing in 5th (overdrive) - and limiting engine power increases by chipping or turbocharging to no more than 10 or 15%.
Regular oil changes also solve the problem of oil quantity reduction caused by slow leaks, which can seriously damage gearboxes.
One BIL backed his '99 Hilux (about 200,000kms) out of his garage and his reverse idler gear popped straight out of the side of the gearbox!
It turned out the gearbox had a slow leak, he hadn't been checking it - and it ran the reverse idler gear bearing dry - which promptly seized - and this broke a chunk out of the gearbox housing, and spat the idler gear out the side!
It was nothing that $2500 didn't fix, as he ruefully related to me later.
Cheers, Ron.
FollowupID: 833632
Follow Up By: 671 - Sunday, Feb 15, 2015 at 12:57
You started by saying it is bit concerning without explaining why. You give people the wrong idea when you do things like that.
Yes I do know how auto transmissions work. Apart from TAFE lessons, I have completed a couple of General Motors training courses on them.
FollowupID: 833633
Follow Up By: jason e1 - Sunday, Feb 15, 2015 at 14:50
Ron n you should see some of the oil that comes out of troop carriers that work underground and that if they have any oil left in them
FollowupID: 833639
Reply By: TomH - Sunday, Feb 15, 2015 at 14:56
Mazdas have run ATF in gearboxes for years.
We swapped a 5 spd into a Mazda 323 in about 1995 Put Gear oil in it and it wouldnt change gears when it was cold.
Put ATF in it and had no more trouble.
AnswerID: 545969
Reply By: swampfox - Monday, Feb 16, 2015 at 17:40
HI
I will list the issues I have had and the ones that r common that I am aware of .
I have a 2wd high chassis PJ High chassis and 4wd are same except transfer case
pj pk mada ford 99% same
First dealer assistance from ford is occasionally good .When u have a problem they will run in the opposite direction .
Poor customer communication if any
Tailshaft centre c/v spline wear and tear can be stuffed at 60,000km nut comes loose
steering box whine normal occording to ford , Bull S*****
steering box very sloppy normal this can be adjusted
gear change truck like after 20,000km
Ford drilled rear diff plug to low there is a recall
bonnet recall
air conditioning absolutely usless in hot weather
[needs bigger condenser 290lbs pressure discharge Ford did a slight degas bleep s ...]
compressor was very noisy at 290lbs
water entry to the body
surging dirty filter
dirty injectors replaced at 70,000kms
picked up 150kms per tank
450-550 a tank
400 a tank towing
seats split and poke u with wire
Other peoples issues I can verify that r also all to common
leaking EGR cooler causing cracked cylinder head/ over heating
EGR filling inlet manifold with junk /carbon
manifold sensors need cleaning every 20,000km
5th gear in some 4wd need a rectification kit
rear diff limited slip function barely works if at all
water entry to cab via the cab breather flaps
some rear diff assemblies explode
Engine conrod bearings wear out prematurely and cause a thrown rod thru engine block
There are cruise control recalls
Engine will not start but turns over ECU issues /crank angle sensor also
[NO FUEL SITUATION ]
Clutch issues with Duual mass flywheel
swampfox
AnswerID: 546029
Follow Up By: jason e1 - Monday, Feb 16, 2015 at 21:27
Swampfox sounds like you have had some drama
Sounds like ford behave like nissan promise the world until you sign on the dotted line then when you have a genuine problem talk to you like your a retard and deny everything
My old man had a navara that had leaking injectors from day one to the point you could not see are car behind you at the traffic lights at night the sump would be 1-1.5 litres over full at each service
The only way we got them to put new injecters in was sit out the front of the showroom on an open day with about 100 people in there and rev it it until the showroom was filled with diesel smoke
Funny how helpful they were after that
FollowupID: 833732
