Friday, Dec 12, 2014 at 22:36
HI
For those who wsh to know what the current draw of their fridge actually is, simply divide the WATT rating by 12V
Then how long it runs for will depend on how it is used including:
Temp that the FRIDGE is operating In
[Anything over 25C means it WILL run longer & use more Amphrs over 24hrs than the 1.5 x24 hrs=36Ahrs the specs give]
Then the actual thermo setting will also determine how long it will run for,near freezing it will run a great deal longer
Iin deep freeze mode it may
well run continiously
Then anything that you put will also cause it to run longer
If it is an upright type[not a chest type] the longer or more often the door is open will encrease the run time.[cold air spilling out, warm air has to be cooled]
Chest types are less affected by LID openings
PeterQ
829645
