Bug and Tar Remover - Tree Sap Residue
Submitted: Thursday, Dec 04, 2014 at 18:56
ThreadID: 110338 Views:2484 Replies:8 FollowUps:1
Hi all.
Every year I do a serious wash on the 200 and then machine buff polish to get rid of tree sap residue. However, I am worried that I may be over-doing it re the polishing; there's only so much before I strart affecting the duco?
Has anyone tried the Armorall or Turtle Wax products for tree sap pls?
Turtle Wax BTR
Armorall BTR
Cheers.
Reply By: Crusier 91 - Thursday, Dec 04, 2014 at 19:55
Petrol
Many detailers use it.
Many fall into the trap of polishing after travelling...........polishing should be done prior to travelling, all the crap comes off easier after the trip.
AnswerID: 542552
Reply By: Les PK Ranger - Thursday, Dec 04, 2014 at 22:58
You are right to be concerned about cut & polishing that often.
Many new car makers now are putting very little paint on, COB (clear over base) colours, traditionally metallics (but more and more solids are using this process) especially.
Remover tree sap and tar spots etc with a good wax & grease remover.
Tree saps can be stubborn and very damaging / staining to paint like bird droppings.
Try not to leave it on too long, and better still avoid parking under trees that drop a lot of sap.
I've never been a big fan of waxes, but some of these might help release such materials, and possible protect the paint a little.
Maybe read some of the info in their promo brochures etc, but consider it marketing jargon in many cases.
You will likely have to try a few brands and see what makes you life easier.
AnswerID: 542560
Reply By: Member - Stephen L (Clare SA) - Thursday, Dec 04, 2014 at 23:22
Hi John
I have in the past either used kero, or CRC sprayed onto the effected sports soon makes light work of getting those issues off without having to use much elbow grease.
Then give your pride and joy a good hand polish with a good quality polish and it will look as good as new.
Smile like a Crocodile
AnswerID: 542562
Follow Up By: Sand Man (SA) - Friday, Dec 05, 2014 at 07:36
Like Stephen, I use a similar product, but in my case WD40.
It actually mentions on the label that WD40 will remove bug residue, amongst a myriad of other uses.
I always carry a canister of it in the vehicle.
Bill
FollowupID: 828969
Reply By: snow - Friday, Dec 05, 2014 at 11:38
I have used both kero and eucalyptus oil with good results
AnswerID: 542593
Reply By: The Bantam - Friday, Dec 05, 2014 at 11:59
Here are some thaughts.
If you want to buff your car.....turn your back on the retail products and go to a good refinish supplier where the panel beaters shop.
Ask for a good quality modern buffing compound.
A medum compound should be fine.....some of the fine compounds are rediculous.
The current terchnology uses very accurately graded and regularly shaped abrasive particles...this results in a product that works fast but is less agressive than the older style retail cutting compounds
The commercial compound you are looking for will have nothing but abrasive and a carrier usually kero and water.
use this with a foam buff, I use an orange buff ( they are colour graded).....forget the lamswool....far too agressive
Slow speed, add water, from a squirt bottle if its starts to dry out.
The object here is to get a realy smooth and glossy surface on which to apply polish
With a light touch you will get a good smooth gloss with little risk......get heavy handed and you can buff out quite deep scratches right back to the metal.
Then apply your polish of choice.
The best I have been able to establish is meguaires gold class
Apply this by hand a buff off by hand as instructed.
It may be worth applying 2 or more applications.
A good coat of wax over a realy smooth surface will tend to reduce things sticking.
But some things are just agressive like bat $###......that stuff is acidic and will get thru anything, you need to get it off fast.
as for getting tree sap and stuff off.
My preference is white spirit (not metho WHITE spirit), it is the base hydrocarbon for petrol and turps, it has less other stuff in it and is clean and clear.....it should not effect sound paint work.
Some tree sap comes of with water better......leave a wet sponge or rag on the sap for half a hour or so then see how you go.
AnswerID: 542595
Reply By: Member - John Baas (WA) - Friday, Dec 05, 2014 at 12:25
Thanks all, for the tips.
Much food for thought there and I'll 'spot try' some of your suggestions.
Cheers.
AnswerID: 542597
Reply By: Flighty ( WA ) - Friday, Dec 05, 2014 at 14:06
Only ever used "Mothers" clay bar on my duco with good results.
Little bit of elbow grease required but doesn't damage the duco
Flighty
AnswerID: 542602
Reply By: Member - mark D18 - Friday, Dec 05, 2014 at 17:38
Elbow grease only.
Never buff unless you are a professional.
Any good quality polish will do the trick.
and as previous punters have said WD40 will work for your intended use.
AnswerID: 542611
