Darwin in dec/jan
Submitted: Tuesday, Dec 02, 2014 at 20:22
Jerry D
Hi travellers,
seriously planning to go to
Darwin from
Newcastle, lifetime dream.
Travelling in 2wd van with my wife.
What the knowledgeable people think?
We did
Newcastle to
Cooktown successfully last dec/jan (and still married).
Was considering to purchase portable AC something like Kogan's for hot nights to use at the parks.
Thanks in advance
Jerry
Reply By: Bigfish - Tuesday, Dec 02, 2014 at 20:47
Cooktown is still not as hot and humid as
Darwin. Nor as expensive. Portable Kogan air-con , in my humble opinion, wont be worth 2 bob. If you get hotel/cabin accommodation then you will be right. Camping is just too bloody hot AND if the storms are about...scary and dangerous. Its getting warm in
Cairns at the moment. I don't use air-con at moment, because I just did 18 years in the top-end and don't find the heat/humidity as bad as further North. You will definitely be sweating and bleep off with the humidity. In a van or tent you will need a lot of air circulating. Even the swimming
pool water is warm and has no cooling effect!
Just not a good time to visit unless your fully acclimatised..
Good luck.
542486
Reply By: Hoyks - Tuesday, Dec 02, 2014 at 23:02
If it is a dream, then go. It's around 3500km each way from my place, but if it floats your boat...
But be prepared to cut and run if things turn nasty.
I flew into
Darwin a 2 years back in late November, it was incredibly humid (water running down the outside of the windows, but not much rain humid) for a few days with occasional showers. Then a cyclone spun up off the coast and crossed as a Cat 1 within a day or two.
The road to
Katherine was under in several
places and the road to
Kakadu or WA, forget it.
I wouldn't want to be any where near a tropical low in a caravan and trying to out run one by heading south can be an issue if the roads close ahead of you. I've had friends that got stuck in Mt Isa when a low stopped in the Gulf and flooded that area for hundreds of km.
Katherine has a nasty habit of getting flooded if a cyclone runs south too.
As for the aircon, get a small window rattler and work out a way to use that. I have had a portable air con in the past and they are not real efficient. You have a noisy machine in the room with you that makes heat with the motor, it cools the air in the room and gets rid of the excess heat by blowing hot air outside, but then has to suck hot humid air in from outside to replace that air it has blown out.
At least a small aircon has the compressor and the heat exchanger outside already and can just recycle the air in the room. They are usually cheaper too.
542491
Reply By: Steve in Kakadu - Wednesday, Dec 03, 2014 at 00:28
We are expecting the monsoon to start in January,
I have done 39 wet seasons / monsoons / build ups, if you love the colour green then please turn up, if you can't put up with the monsoon, wet season or cyclone season, then you may need to re think you trip.
Have fun if you want to see the Top End in all it's glory then pick a date some where between January and December.
542494
Reply By: Member Andys Adventures - Wednesday, Dec 03, 2014 at 09:07
Hi Jerry,
Everyone is going on about the heat, but it's
places that are closed in the wet season, you will miss a lot. In the dry a 2wd on dirt roads are no problem, but in the wet it will be a no go.
Saying that there is still a lot to see and do.. enjoy your trip, and I'm sure you will be back in the dry to finish what you left...
As for air con I would forget it, just use the tent without the fly. And I find a nice hot shower before bed works.
Cheers Andy
542498
Reply By: Top End Az - Wednesday, Dec 03, 2014 at 12:23
I'm all for following your dreams and getting out there and just doing it. As a
Darwin local (for 14 years) it is very humid and hot as the other posts have said. In my opinion it is also the prettiest time of the year, every thing is green and lush.
Just keep in mind that when we get a cyclone come through (which they do every year), or have a heavy monsoon, you may get stranded for a period of time as many of the roads go under. If you aren't in a rush or on a timetable, and you are flexible then it won't be a problem.
The only other thing to consider is that many of the roads into the National Parks are closed too due to flooding so sight seeing options will be reduced.
Hope this helps.
542504
Reply By: Kelpie D - Wednesday, Dec 03, 2014 at 14:45
It will send you "troppo".
It is the wet season...
If you can, plan the trip for the middle of the dry (your winter). It is worth going, just not in the wet.
Once you have done a dry season trip, then plan out your wet season. Trust me, I have been there done that. Arriving in
Darwin in the middle of the wet, if you have never done it before, is no fun at all.
542508
Reply By: Kumunara (NT) - Wednesday, Dec 03, 2014 at 21:49
Jerry
Living in
Katherine I love the wet season - the rain, lightning and thunder is fantastic. The top end is at its best, lush and green.
However it is hot and humid and for someone who is not used to it - very oppressive.
Katherine itself has been flooded twice in recent times - 1998 and 2006.
The Stuart Highways does get closed due to the wet occasionally. Other roads do get cut by rising rivers at times. This can make it difficult for travellers. Over the years the roads have been improved by building bridges, etc, but is still a problem when travelling.
Tjilpe
542519
Reply By: BrettP - Thursday, Dec 04, 2014 at 17:52
Seriously would have to be the worst time of year to visit
Darwin. Having lived there for 4 years, the weather around Xmas time isn't always that bad, still pretty humid, and afternoon rain.But come January then it just gets a bit ridiculous.Roads are cut, creeks swollen and it's downright hot and uncomfortable.As for camping in it...no way, and no air con apart from refrigerated works .I'd leave it til late April and go, but then most of the popultaion goes at that time too..You won't get into a lot of
places due t oraod conditions,and if you get in, you may not get out for a few days until the creeks levels drop..
542546
Reply By: Jerry D - Thursday, Dec 04, 2014 at 22:38
OK travellers,
thank you all for good recommendations
after serious thinking we decided to accept your advise & postpone our NT trip
for june/july. Sadly ...
If still possible, we follow with second, wet season trip after gaining some experience.
It was very interesting to read such a good reviews...
Thank you all again
Jerry
542559
Follow Up By: Member - PhilD_NT - Thursday, Dec 04, 2014 at 22:54
A bit of a shame really as the Wet Season (a.k.a. Green Season) has it's own attractions, but it's just not really suited to tenting it and touring to many
places. Been here for most of the last 40 years, with stints elsewhere in the NT, and intend staying a lot longer. So nice today that I didn't even have to put on the spa solar heater as water was at a natural 32 degC. Getting bypassed by a lot of storms but spectacular to watch mostly.
828965
Reply By: Tony O1 - Friday, Dec 05, 2014 at 19:58
Dude,
are you out of your mind. My advice, fly there, rent a car and get a motel with aircon. You will only be able to see stuff in
Darwin as other
places such as
Litchfield are closed
Rain and floods don't have schedules or predictable times.
You will die if you are not acclimatised and it will be the holiday from hell. Most attractions are closed as
I am about to drive back up to live there for the third time. Motels all the way and get there as fast as I can in case the monsoon comes early
542621
Follow Up By: Steve in Kakadu - Friday, Dec 05, 2014 at 22:58
Not sure why you bother coming back really.
829020
Follow Up By: Norm C (WA) - Friday, Dec 05, 2014 at 23:05
As Steve says You would have to wonder why you would bother going back seems your saying Don't go your a fool if you do I'm going just to prove it Are you out of your mind?
829021
Reply By: Iosef - Friday, Dec 19, 2014 at 18:05
Only you know what your tolerance is for doing it a bit tough. I've done many trips where people told me it was a no-go and had a ball every time. That includes the Top End for five weeks in December/January. Did
Kakadu,
Litchfield and
Gregory during that time. Have done
Cooktown in the wet too. Just about fell over from heat stress digging two cars out of the bog in
Kakadu but that's just an amusing foot note to all the good memories. We do stretchers under a tarp - mozzie net optional depending on the mozzie situation. Keep in mind the flies can be horrific in certain parts that time of year too but at least they go away at night.
I guess I like a bit of a challenge and don't mind discomfort. If you have any hard deadlines, I would be wary of getting trapped in by the wet but if not, go for it. You can always fly out if it's your daughters wedding or something.
543154
