OziExplorer - New PC (3.95.6a) and Android (1.24) Versions
Submitted: Sunday, Nov 30, 2014 at 23:25
ThreadID: 110302 Views:3786 Replies:4 FollowUps:5
Hello
See OziExplorer Website for the specific details.
Reply By: Member - graeme W (WA) - Monday, Dec 01, 2014 at 14:03
Hi Greg.Do you know what improvements there are. Pity there is not some sort of file arrangement for waypoints where you copy only the waypoints you want instead of a double of everything from one device to another. I do a lot of volunteer work for dpaw logging orchids and carry a small gps in the field and copy the waypoints to a tab for a screen shot of a particular area. Unfortunately without first deleting everything on the one i carry you just end up with double or treble depending how many times you transfer from one to another . Unless someone knows a better way.
cheers Graeme.
AnswerID: 542431
Follow Up By: Frank P (NSW) - Monday, Dec 01, 2014 at 14:13
I like the addition of a floating scale.
FollowupID: 828769
Follow Up By: The Explorer - Wednesday, Dec 03, 2014 at 13:33
Hello Graeme
The "improvements" are listed under "History of Changes"/Program History" on respective web pages.
I am unsure of what you are actually doing to get "double of everything from one device to another" when transferring waypoints. Suspect you just need to change the way you are doing things to prevent this.
I would suggest doing all your data management on a PC using full OziExplorer (not on the tablet or GPS) as it has more options and it easier to add/delete/modify data files (waypoints and tracks) than android version. This should solve your problem.
FollowupID: 828912
Reply By: equinox - Monday, Dec 01, 2014 at 22:14
Des doesn't sound to happy with the Android developers.
AnswerID: 542450
Follow Up By: The Explorer - Monday, Dec 01, 2014 at 22:44
Yeah..thats a bit strange ..a "bug" or maybe Google hired an ex Apple programmer who had never heard of an SD card or thought restricting the users ability to save/access files (which belong to the user) to/from where they want was normal practice :)
Chees
FollowupID: 828821
Reply By: The Explorer - Friday, Dec 05, 2014 at 16:23
NOTE ...PC version just updated again to fix minor bug related to map scale/calibrating maps - now V 3.95.6b.
AnswerID: 542608
Follow Up By: Zebra400 - Saturday, Dec 13, 2014 at 12:28
Des updated Ver 3.95.6b again on Sunday 7 Dec. If you tried to navigate to a waypoint, you would receive an exception error. You had to then reboot Ozi to continue.
Des didnt change the version number, so if you downloaded Ver 3.95.6b before Sunday before midday, then you wont have the latest release of that version.
Laurie
FollowupID: 829674
Follow Up By: Zebra400 - Saturday, Dec 13, 2014 at 12:31
I also see that there is a later release of the android version. The latest version is now 1.25
FollowupID: 829675
Reply By: The Explorer - Friday, Dec 12, 2014 at 23:33
....Android Version updated the other day to 1.25
* Fixed problem with OziExplorer crashing on certain devices on startup.
* Fixed problem with the map scale bar not displaying correctly for "nm / meter" distance unit setting.
Ozi Android WebPage
AnswerID: 542915
