toshiba laptop problem
Submitted: Thursday, Nov 20, 2014 at 14:25
ThreadID: 110196 Views:1779 Replies:3 FollowUps:3
Hello all , recently I switched off my toshiba lsptop now when I switch it on it appears that the keyboard has frozen.
I cannot type anything at all.
The screen has power but I cannot type in the password, can anyone suggest a possible solution ???
Reply By: FatGaz - Thursday, Nov 20, 2014 at 14:39
1- Turn off computer, disconnect the power cord, remove the battery.
2- Press the Power On button for 10 seconds
3- Replace battery and/or connect power cord.
4- Turn On computer + immediately press F2 key repeatedly
5- Press F9 then press Enter
6- Press F10 then press Enter
Good Luck
AnswerID: 541907
Follow Up By: Member - Duncan W (WA) - Thursday, Nov 20, 2014 at 16:20
FatGaz
Does that work for any laptop or is that fix peculiar to Toshiba's?
Dunc
Dunc
FollowupID: 828131
Follow Up By: mikehzz - Thursday, Nov 20, 2014 at 20:09
Removing the power and the battery and holding the power button in for 10 seconds fixes quite a number of laptop problems for most brands. It's a handy trick that clears the charge held on certain motherboard components that may be halting the boot process. All the F keys are brand specific.
FollowupID: 828143
Reply By: pepper2 - Thursday, Nov 20, 2014 at 15:23
Thankyou , thankyou , thankyou...it works perfectly....your blood is worth bottling.
AnswerID: 541909
Follow Up By: OBJ - Thursday, Nov 20, 2014 at 17:50
... even if it is just for the alcoholic content :)
OBJ
FollowupID: 828134
Reply By: Member Andys Adventures - Thursday, Nov 20, 2014 at 17:47
you may have turn off the pad. The switch is below the space bar and hard to see push that and it should work. If not my last Toshiba I had to replace the key board, but that gave me warning.
AnswerID: 541921
