Solar Panel Mount
Submitted: Friday, Nov 07, 2014 at 08:28
Grant S2
I'm searching for a 'locking pivoting ball mount' to attach the 80W solar panel to. I'd appreciate any information/ideas.
Reply By: Bob Y. - Qld - Friday, Nov 07, 2014 at 10:51
Can't help you with your search for a pivoting ball mount, Grant, but back in another life, we put in about 6 Mono self tracking arrays for stock water pumps.
Admittedly the arrays were much bigger than your 80 watt panel, but the mounting arrangement was very robust, and heavy, because of the potential wind loading. Even an 80 w panel will need some strong mounting points to protect against the odd wind gust. You haven't said where you'll be mounting this panel?
Below is what I did with a 160 w panel on our slide-on camper.
Hinged Solar Panel
Used 3 x 300mm s/steel hinges on leading edge, pop riveted onto front of pack rack, 2 gas struts and 2 s/steel slide bolts, to lock the panel while travelling,
Slide Lock for Travelling
While this set up is somewhat of a compromise, as far as getting maximum output from the panel, it's an easy fix for travelling.
541387
