resistor on non resistor relay which one?
Submitted: Tuesday, Nov 04, 2014 at 23:10
ThreadID: 110042 Views:16097 Replies:6 FollowUps:23
I am a little confused as the suitability of which relay to use for the job described below.......in fact I have always purchased a "relay" in the past and not seen the types as described above before...change over relay or normal relay ...yes that is straightforward....
These switches fit perfectly into the Land Criser 200 series dash blanks just like an OEM
Please see the diagram below DIAGRAM 1
My understanding is that a relay can at times send a spike of current or voltage in reverse when the coil is disengaged in the relay.........wouldn't perhaps matter in a mechanical switch but these switches have an electronic switch circuit and can be damaged if this happens
My question is two fold...what type of relay to use?......
Secondly is a 3 amp blade fuse in line between the switch and pin # 86 going to protect the switch circuit?
Thanks in advance
VKS 1341
