ARB compressor air hose
Submitted: Wednesday, Sep 03, 2014 at 13:57
Krooznalong
The hose I have (that curly
orange plastic stuff) has a few cracks developing and needs replacing. Is it possible to buy that type of hose by the metre and re-use the existing fittings? Who sells that stuff?
Thanks in advance.
Reply By: MUZBRY- Life member(Vic) - Wednesday, Sep 03, 2014 at 14:15
Gday
You should be able to use a "Suzi coil" purchased from Repco or Bursons and all truck parts dealers.
538563
Follow Up By: Krooznalong - Wednesday, Sep 03, 2014 at 14:29
Thanks Muzbry - first time I've heard of Suzi coil. Never too old to learn something!
823068
Follow Up By: Bob Y. - Qld - Thursday, Sep 04, 2014 at 08:16
Those Suzi coils are really strong, Muz. In a dither one night and forgot to unhook them............must have stretched 30' before they broke. :-)
Rather have something like Derek's supplying for tyre use though.
823102
Reply By: ABR - SIDEWINDER - Wednesday, Sep 03, 2014 at 14:19
We have a 8m rubber hose, you can change the fittings over.
Derek from ABR
538564
Follow Up By: Krooznalong - Wednesday, Sep 03, 2014 at 14:28
Derek - what's the outside diameter? I need it fit into a particular space, thus the question. If it's a fair bit larger than the original it will not fit.
823067
Follow Up By: ABR - SIDEWINDER - Wednesday, Sep 03, 2014 at 14:44
10mm OD and 5mm ID. The hose can be coiled by hand to what ever you want down to say 120mm if needed.
823069
Follow Up By: Bludge - Wednesday, Sep 03, 2014 at 18:12
I have one of those... I also have the ARB hose, had to get rid of those curly things.
823080
Follow Up By: MUZBRY- Life member(Vic) - Thursday, Sep 04, 2014 at 07:25
Sorry Derek
I hadn't thought of recommending you. I don't like the coily hoses and so must get rid of the one i have.
823096
Follow Up By: Member - Phil 'n Jill (WA) - Thursday, Sep 11, 2014 at 22:47
I replaced my orange/yellowy hose with Derek's hose - good gear.
Regards - Phil
823573
Reply By: Member - John T (Tamworth NSW) - Wednesday, Sep 03, 2014 at 14:28
Reply By: Wayne's 60 - Thursday, Sep 04, 2014 at 14:20
Krooznalong,
I don't recall any ARB compressor that has curly hose.
Or,
Are you after a replacement ARB branded, compressor hose?
Lots of
places sell high pressure hose by the metre and ARB sell their
orange compressor hose as a complete unit.
Wayne & Sally.
538595
Follow Up By: Krooznalong - Thursday, Sep 04, 2014 at 14:31
It's definitely an ARB compressor (portable - but I've mounted it in rear of the Cruiser) and it definitely has what I call "curly" hose - it's horrible stuff that tends to tangle and is a PITA to stretch out around the back to try to reach the front wheels.
So I don't really want the same stuff again. Was after something I can buy in the length I want and just take the current fittings off and transfer them to the new hose.
823126
Follow Up By: Wayne's 60 - Thursday, Sep 04, 2014 at 18:50
Krooznalong,
It is interesting that we have the same compressor, with the straight
orange high pressure line. I wonder if ARB changed from the curly to the straight line??
Anyone who sells compressors will have the line you need and as indicated before, ARB sell the hose and fittings complete.
Hope you get is sorted soon.
Wayne & Sally.
823141
Follow Up By: Gronk - Thursday, Sep 04, 2014 at 18:55
I think what he means as "curly" is in fact the
orange hose that normally gets wound in a circle, thus making it look curly......and needs to be "uncurled" to go straight ..
Just like a garden hose, an air hose will need uncurling to go straight..
823142
Follow Up By: Krooznalong - Friday, Sep 05, 2014 at 07:33
I call it "curly" because that's the natural state it wants to be in. No way would it lie straight unless it's stretched out.
823164
Follow Up By: Wayne's 60 - Friday, Sep 05, 2014 at 09:25
It is interesting to do an image search of ARB compressors.
One does have the same type of "curled" hose that cheap compressor makers favour.
Having limited space would tend to steer towards the thinner tube stock.
Let us know what you end up doing.
Wayne & Sally.
823169
Follow Up By: Krooznalong - Tuesday, Sep 09, 2014 at 10:04
Thanks for all the suggestions.
I ended up getting some reinforced clear hose from Masters at $1.60 per meter and put the fittings from the buggered hose onto the new stuff. Problem solvered.
823409
Follow Up By: Wayne's 60 - Wednesday, Sep 10, 2014 at 23:41
Krooznalong,
Thanks for taking the time to come back and say thank you and to let us know what you did to sort the problem.
Wayne & Sally.
823520
Reply By: desray (WA - Thursday, Sep 04, 2014 at 23:10
you can buy the air hose and fittings at Bunnings,, super cheap auto has them also
538622
Follow Up By: Gronk - Friday, Sep 05, 2014 at 10:57
I think you'll find that ARB have a different style of chuck than others, so an ordinary hose fitting won't connect to an ARB compressor..
823180
