Friday, Aug 22, 2014 at 21:06
Hi Kevin,
You haven't mentioned what capacity engine you have, but you may find a
home built catch can, that is smaller than a Provent and plumbed back through the intake, won't stop the oil going through to the engine,
due to the intake air speed.
The Provent is purpose built to handle it and sized to engine size.
I used the s/s pads like
John used with metal gauze to secure it, then the fumes went around a baffle to exit out the top.
Unless vented to atmosphere (not legal), the can will most likely need to be larger than 3ltrs on a 3ltr turbo engine.
Others may have more on this.
If you have a size and configuration that works, it would be good to see the plans/photos for others to build.
Good luck and hope this helps
822317
