Are vehicle awnings more useful on the side or out the back?
Submitted: Thursday, Aug 14, 2014 at 11:59
Krooznalong
If you've had experience with both vehicle mounted awning options which, did you find most useful?
Whilst the most common positioning is on the side, I'm leaning towards putting one on the rear where I imagine it would be great for protection at the food preparation area (100 series Cruiser - we use the tailgate as the table). And it would still provide shade etc at other times. Main disadvantage I see is that it will be harder to attach to the roof rack.
Thanks in advance for your replies.
Reply By: olcoolone - Thursday, Aug 14, 2014 at 12:59
Left hand side....... right hand side is to close to the road and out the back makes the overall length of the vehicle to long when parked.
The side mounted ones can be longer up to 2.5m long whereby at the back only 1500 wide.
If you have a lift up tail
gate it makes it very hard to mount a rear awning.
We find the rear lift up tailgate offers all the protection we need when prepping food.
537648
Follow Up By: Krooznalong - Thursday, Aug 14, 2014 at 13:32
Thanks olcoolone
Umm - yeah forgot about the fact that it needs to be quite narrow for the rear. So looks like the side it needs to be.
BTW - we find the rear lift up tailgate only protects the food, not the prepper!
821882
Reply By: baznpud (tassie) - Thursday, Aug 14, 2014 at 13:13
Don't know where you get them from, or what the brand is, but there is one available that goes down the side and across the back.
baz
537650
Follow Up By: baznpud (tassie) - Thursday, Aug 14, 2014 at 13:18
Just googled, try www.roofrackcity.com.au they are called a Fox Wing Awning.
Not cheap though.
baz
821881
Follow Up By: Krooznalong - Thursday, Aug 14, 2014 at 13:35
Thanks baz
Only after one for occassional use so not going to pay that sort of $s.
821883
Follow Up By: cookie1 - Thursday, Aug 14, 2014 at 15:21
They're a real bugger to put up in the slightest of wind, I went the ARB side awning
821887
Reply By: andoland - Thursday, Aug 14, 2014 at 14:03
Reply By: Les PK Ranger - Thursday, Aug 14, 2014 at 18:17
Probably not too much hassle to prepare lunch in relatively fine weather, in the sun for a while etc . . . but maybe for inclement weather you can use a couple of large bulldog clips and pin a bit of canvas or bratus sheet (might need a couple of corner weights for this) at the back, roll down over the window and prepper for the time spent getting sandies made, coffee brewed etc, then retreat to the left side awning . . .
Good to lay on it too if needing to get under the vehicle, or use as a ground sheet, etc.
537656
Follow Up By: Les PK Ranger - Thursday, Aug 14, 2014 at 18:21
Just remembered, there's always a Freds Arm solution . . .
Freds Arm from Black Widow
Google Freds Arm, plenty of links come up . . .
A little pricey with the cost (~$395) on top of awning purchase, but if you're handy with a welder, you could probably make this yourself too.
821900
Reply By: philw - Thursday, Aug 14, 2014 at 20:32
Anaconda have the Quick Stop Side Awning and the rear R.V. Awning available. You get both for under $200 and they work a treat. 10 minutes to set up both.
537660
Reply By: Life Member - Terry 80FTE - Thursday, Aug 14, 2014 at 21:06
Mine gets most use over the tailgate as it's our "kitchen" as
well, big benefit is it stops the sun shining in on your beer when the fridge gets slid out;)
2mtrs wide and extends 2.4mtrs, mounted on the side and pivots around to the rear, alah freds arm.
I'll swing it around and set it up if even only for a coffee stop as once you get a handle on it, it only takes a minute or 2, probably getting out the hammer and pegs, roping and pegging down use half the time,
Coffee Mmm. did someone mention Coffee...
Was on a big trip with a mate a few years ago who had a 2.4mtr on the side and one the width of, and mounted on the rear, the rear one was handy but not wide enough to
shelter from the rain or sun properly and only just kept the dew off the swag.
On the side is good if needing a bit more
shelter, or using a small tent/ swag to
camp.
537661
Follow Up By: Life Member - Terry 80FTE - Thursday, Aug 14, 2014 at 21:10
Check ALDI catalog this Sat.
821916
Follow Up By: Les PK Ranger - Thursday, Aug 14, 2014 at 22:26
Terry, a good tip for setting up awnings securely . . . don't string rope out and peg at 45o, I just do a few half hitches down the 2 vertical poles, and hammer peg straight into the ground at the base of each pole.
No ropes to trip over.
One of these days, I will drill a hole in the bottom inch of each pole, tie a loop of cord in each, and just peg down from that directly, eliminating the 2 ropes altogether :)
821921
Follow Up By: Life Member - Terry 80FTE - Friday, Aug 15, 2014 at 18:49
Thanks Les, usually take the ropes straight down to peg in unless it's a bit breezy, then out at 45o is more secure,
Trees, other vehicles etc also can get a look in.
821956
Reply By: Michaeljp - Thursday, Aug 14, 2014 at 22:02
4WD supacentre.com.au has them for between $150-$199.
537663
Reply By: Freshstart - Friday, Aug 15, 2014 at 08:45
On the left hand side, especially a long one. We have a roof top tent that opens over the the rear.
537681
Reply By: Member - Scrubby (VIC) - Friday, Aug 15, 2014 at 19:40
My side awning measures 4.2 m along the side and 4 m out, this attaches to the rear section that is 2 m across the back by 2 m out.
When assembled it is an " L" shape 4.2 m x 6 m.
Sufficient eyelets allows for different setups, the side awning can be set with part of the roof used as a wall, either along its length or across the end.
The rear (2x2) section is removed and folded for traveling, the side awning has 1 m each end folded over and then the whole section is rolled up and placed in the pack rack, held in by stretchy cords.
If just stopping for a cuppa or whatever, the rear awning is large enough and quick to set up.
Scrubby
537728
Reply By: Mark T6 - Saturday, Aug 16, 2014 at 11:50
I have done thousands of Km's off-road, have had one of these for 5 years and as I mostly travel these roads in the winter period I have hardly ever pulled it out to use.
In fact its a point of some conjecture between, she who must be obeyed and myself, she calls it "the greatest lemon I have ever purchased".
I pulled it out once somewhere between
the Dig Tree and
Cameron Corner on an unusually hot day where there wasn't a tree in sight, so once in 5 years means she's probably right.
Mind you I have pulled it out 2 or 3 times up at Fraser Island as we go up there a bit (living in
Brisbane as I do). Particularly good when setting up on
the beach to let the kids (or in my case the grandkids) go for a swim at
Eli Creek.
Now I know some people use them to
camp under, and yes those Fox Wing ones are smick BUT would I put another one on my next 4WD......probably not!!
537758
Reply By: Member - Scott M (NSW) - Saturday, Aug 16, 2014 at 12:54
I have a SupaPeg on the side of my canopy. Use it all the time. Less than 3 mins to put up and less than 5mins to put away - even quicker if you have help.
No affiliation, however the SupaPeg is one of the easiest and most robust awning I've seen on the market. The rest of our 4WD club liked it so much, there are aorund a dozen of these on various vehicles.
537761
Reply By: Trevor P4 - Saturday, Aug 16, 2014 at 21:36
Krooznalong
I too have a 100 series with
barn doors though.
I gave this problem some thought so I purchased 25 mm square tube to fit the whole length of the side of the truck from just behind the
snorkel to the rear of the car and pop rivited sail track to it. I then had a lightweight canvas awning made 3.5 m out from the side of the car to fit to the sail track. (lightweight being the key)
I have modified the ARB roof rack feet kit and added three flat bars to them to carry a Yak. On the driver's side bolts I welding threaded rod on top of the original ARB bolts and use three windnuts to hold the awninig in place.
On the flat bar at the rear I welded two extra pieces of rod, so by undoing the three wingnuts from the side I can reposition the whole awning to the rear of the car using seperate holes in the tube and two of the three wingnuts from the side in about two minutes.
Due to the long length of the awning when on the side it makes for a wide awning at the rear when mounted (about 600 mm wider on each side).
This allows both
barn doors to be fully open with the whole back of the truck dry and/or shaded
I carry two spreader bars and four poles under the back
seat of the LC to hold the awning up.
Works a treat
537783
Reply By: bradjenny54 - Sunday, Aug 17, 2014 at 09:09
Hi. I've got BT50 with a drop side tray and canopy and my awning is side mounted. My food prep area is there next to the 60ltr Engel all under the awning. Side mount lets you have a larger awning. Brad
537797
